127
How can I change my default text editor from gedit to Emacs?
belacqua
  • 23,540
12 Answers12
129
Here is what worked in my case:
  1. Right click on a text file.
  2. Choose "Properties" (not "Open With...")
  3. Click on the "Open With" tab.
  4. Choose your new text editor.
  5. Mark chosen text editor using a button "Set as default".
This also works on 12.04 and 13.04.
Edit: based on comments it still works in 22.04.
Benjamin
  • 2,225
73
To change default text editor across the file types, try updating gnome-text-editor configuration.
sudo update-alternatives --config gnome-text-editor
In some cases:
sudo update-alternatives --config editor
kn_pavan
  • 1,091
21
I don't use a DE, but for my configurations the next command is the best:
/usr/bin/select-editor
  • it selects your default sensible-editor from all installed editors
  • must run with current user
  • you must have more than one editor in your system
Man pages select-editor
Pilot6
  • 92,041
oshliaer
  • 363
16
A more robust solution would be to replace the bindings in /usr/share/applications/defaults.list.
sed -i 's/gedit/emacs/' /usr/share/applications/defaults.list
Pandu
  • 143
12
Right click on a text file, point to "Open With" and it'll show other editors in a sub-menu. Click on "Other Application...". It'll show you a dialog with a list of applications, select Emacs and make sure the "Remember this application for "plain text document" file" option is checked. Click "Open".
Mussnoon
  • 5,236
12
If you are working from the terminal then I would add the following to your .bashrc file (or the config file for your favorite shell):
export EDITOR=emacs
export VISUAL=emacs
haziz
  • 3,067
You can set the default text editor for a specific user in # ~/.local/share/applications/mimeapps.list by:
[Default Applications]
text/plain=gedit.desktop
For global configuration for all users you have to modify the /etc/gnome/defaults.list
panticz
  • 1,936
On Ubuntu 20, you need to change the gnome-text-editor alternatives link from gedit to the one you want. However, there usually is only one such editor detected so update-alternatives --config won't work; you'll have to add the editor you want.
E.g. to add notepadqq:
sudo update-alternatives --install /usr/bin/gnome-text-editor gnome-text-editor /usr/bin/notepadqq 50
Matthieu
  • 506
For some reason I had to use xdg-mime:
xdg-mime default org.gnome.gedit.desktop text/plain # For current user
you can use your system-wide .desktop files under /usr/share/applications/ or local files under ~/.local/share/applications/ or create your own.
edit: It's also helpful to know that user configurations are stored in ~/.config/mimeapps.list which overrides the defaults. source: https://stackoverflow.com/a/64850938/9085151
etzl
  • 51
sed -i 's/gedit/emacs/g' /etc/gnome/defaults.list
cml.co
  • 133
If you would like to replace gedit with any other text editor for all file types, the easiest is to edit the defaults.list file located here:
Just find and replace all gedit.desktop references with your own editor (in this case emacs.desktop). You need root permissions to edit the file. So, just do:
sudo -H gedit /usr/share/applications/defaults.list
Save the file, close it and it's done.
muru
  • 207,228
ayurdal
To set Pluma as default text editor for all user (global):
sudo sed -i 's|text/plain=gedit.desktop|text/plain=pluma.desktop|g'  /etc/gnome/defaults.list
muru
  • 207,228
panticz
  • 1,936
