I'm trying to provision a VM with cloud-init and the server live image. (I'm not using the cloud image, for infrastructural reasons I have to install from ISOs)
However, whenever I'm trying to combine autoinstall with e.g. write_files, the write_files part does not seem to succeed.
The following installs Ubuntu:
#cloud-config
autoinstall:
  version: 1
  identity:
    hostname: boxy-001
    password: "$1$k46kl1..."
    username: alice
  storage:
    layout:
  ssh:
    install-server: true
    authorized-keys:
      - "ecdsa-sha2-nistp256 AAAAE2...."
write_files:
  • content: |
    cloud_init_has_run
    path: /cloud_init_flag
But the file is not written at /cloud_init_flag.
Are modules missing? Is cloud-config incomplete on the Server live ISOs?
Edit the file is written, but it's written in the installation environment! Instead, I should likely use the autoinstall.user-data key to provide the user-data for the target system.
Tom
  • 213
how would I get cloud-init to run on the installed system in combination with autoinstall?
There is a user-data config key for the autoinstall file.
For example, if you want your write_files configuration to be used by cloud-init on the installed system then this snippet could be included as part of the autoinstall file.
#cloud-config
autoinstall:
  version: 1
  user-data:
    write_files:
    - content: |
        cloud_init_has_run
How it works
  • During the install, subiquity will create configuration for cloud-init at /target/var/lib/cloud/seed/nocloud-net/user-data.
  • During the first boot of the installed system, cloud-init will use this config file to perform some of the install tasks. Notably, this is how the first user is created.
  • If a user-data section is included in the autoinstall file then subiquity will merge the user-data section into the generated /target/var/lib/cloud/seed/nocloud-net/user-data file.
Using the snippet above, the merged configuration resulted in this file content.
#cloud-config
growpart: {mode: 'off'}
locale: en_US.UTF-8
preserve_hostname: true
resize_rootfs: false
write_files:
- {content: 'cloud_init_has_run
', path: /cloud_init_flag}
During first boot, cloud-init did create the /cloud_init_flag file with the configured content.
