sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  fwupd-signed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
apt-cache policy fwupd fwupd-signed
fwupd:
  Installed: 1.5.8-0ubuntu1pop0~1617221312~20.10~a9de48d
  Candidate: 1.5.8-0ubuntu1pop0~1617221312~20.10~a9de48d
  Version table:
 *** 1.5.8-0ubuntu1pop0~1617221312~20.10~a9de48d 100
        100 /var/lib/dpkg/status
     1.4.7-0~20.10.2 500
        500 http://us.archive.ubuntu.com/ubuntu groovy-updates/main amd64 Packages
     1.4.5-1 500
        500 http://us.archive.ubuntu.com/ubuntu groovy/main amd64 Packages
fwupd-signed:
  Candidate: 1.30.2+1.4.7-0~20.10.2
  Version table:
     1.30.2+1.4.7-0~20.10.2 500
     1.30+1.4.5-1 500
Zanna
  • 72,312
If a package is "kept back", that means the upgrade command will not upgrade it because doing so would require installing or removing other packages. You can override this with the install command:
sudo apt-get install fwupd-signed
It will list which packages it has to install or remove in order to upgrade that, so make sure it's not removing anything you care about.
In your case, it looks like you have versions of fwupd and fwpupd-signed that were provided by Pop_OS!, but you no longer have the Pop_OS! repositories configured. If you are using Pop, you should add their repositories, then try doing sudo apt-get update && sudo apt-get upgrade again: https://apt.pop-os.org/
If you're not using Pop, then you can force Ubuntu to install its versions instead. Try:
sudo apt install fwupd=1.4.7-0~20.10.2 fwupd-signed=1.30.2+1.4.7-0~20.10.2
Minneyar
  • 834
