I connect to Openvpn but then my internet connection is lost as I cannot load webpages. Here are some details. I use KDE plasma desktop and problem still persists.
ip route (before connecting to openvpn)
169.254.0.0/16 dev enp0s31f6 scope link metric 1000
192.168.0.0/24 dev enp0s31f6 proto kernel scope link src 192.168.0.221 metric 100
ip route (after connecting to openvpn)
default via 192.168.0.1 dev enp0s31f6 proto dhcp metric 100
128.0.0.0/1 via 172.30.88.1 dev tun0
141.52.8.20 via 192.168.0.1 dev enp0s31f6
172.30.88.0/22 dev tun0 proto kernel scope link src 172.30.91.215
Below outputs are after connecting to openvpn
traceroute 8.8.8.8
Output:
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
1 172.30.88.1 (172.30.88.1) 59.462 ms 59.450 ms 59.447 ms
2 141.52.3.129 (141.52.3.129) 59.438 ms 59.427 ms 59.440 ms
3 129.13.36.1 (129.13.36.1) 59.378 ms 59.392 ms 59.377 ms
4 141.52.249.254 (141.52.249.254) 64.566 ms 64.472 ms 64.497 ms
5 141.52.249.226 (141.52.249.226) 64.894 ms 141.52.249.227 (141.52.249.227) 64.895 ms 64.883 ms
6 193.197.63.6 (193.197.63.6) 66.476 ms 33.209 ms 34.324 ms
7 129.143.60.115 (129.143.60.115) 36.969 ms 36.943 ms 188.1.144.222 (188.1.144.222) 48.418 ms
8 209.85.172.242 (209.85.172.242) 51.037 ms 51.057 ms 142.250.162.80 (142.250.162.80) 41.897 ms
9 * * 108.170.252.65 (108.170.252.65) 47.951 ms
10 8.8.8.8 (8.8.8.8) 46.857 ms 46.789 ms 47.315 ms
route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 172.30.88.1 128.0.0.0 UG 0 0 0 tun0
0.0.0.0 192.168.0.1 0.0.0.0 UG 100 0 0 enp0s31f6
128.0.0.0 172.30.88.1 128.0.0.0 UG 0 0 0 tun0
141.52.8.20 192.168.0.1 255.255.255.255 UGH 0 0 0 enp0s31f6
169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 enp0s31f6
172.30.88.0 0.0.0.0 255.255.252.0 U 0 0 0 tun0
192.168.0.0 0.0.0.0 255.255.255.0 U 100 0 0 enp0s31f6
I have tried this GNOME solution https://askubuntu.com/a/713066/1095090, but I cannot see openvpn connection option in my network manager. All I see is the wired network through which internet works (if not connected to openvpn)
Can anyone suggest how to solve this issue in Kubuntu20.04? Been struggling to solve this since months. Thanks
