-1
I want to resize the home partition to have only 500gb, so then i can make a dual boot setup.
HD /home partition Image
SSD linuxSO partition Image
You should be able to do it no problem but as correctly stated above, you must boot into a live session to do it. GParted can't do it while the partition is mounted.
GParted is pretty straightforward to use, but if you need further guidance, don't hesitate to ask.
The procedure is different to installing Ubuntu with Windows already installed.
If you want to install Windows 10 in Ubuntu, make sure that the intended partition for the Windows OS is the Primary NTFS partition. You need to create this on Ubuntu, specifically for Windows installation purposes.
To create the partition, use the GParted or Disk Utility command-line tools. If you already have a logical/extended partition, you’ll need to delete it and create a new Primary Partition. Keep in mind that all data in the existing partition will be erased.
Installing Windows 10 Use the bootable DVD/USB stick to start the Windows installation process. First, you’ll need to provide the Windows Activation Key to authenticate your installation. After this, choose Custom Installation, because the automatic option may create issues.
Make sure that you select the NTFS Primary Partition that you’ve created earlier as your Windows 10 installation partition. Keep in mind that after the successful Windows 10 installation, GRUB will be replaced by the Windows bootloader, meaning that you won’t see the GRUB menu when booting your computer. Fortunately, this is easy to solve by installing GRUB for Ubuntu again.
Installing GRUB for Ubuntu In order to install and fix GRUB, a LiveCD or LiveUSB of Ubuntu is a must. This means that you’re going to have to get an independent version of Ubuntu. Having a pen drive is ideal here, as you can use it easily.
Once Live Ubuntu has been loaded, open the Terminal and use the following commands to start boot-repair to fix GRUB for Ubuntu:
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
After the installation is done, boot-repair will launch automatically. Select the recommended repair option when repairing the GRUB. Once everything is done, reboot your computer and you’ll see the GRUB menu, where you choose which OS you want to run.
The above information was obtained from this website.
