I need to work with a .swf file from the browser, but I have not been able to install Adobe Flash.
muru
  • 207,228
alons0oo
You can't, Adobe stopped supporting Flash and all Flash games and other things that use Flash will be blocked.
Although you can still install Flash today but it is discouraged as unofficial packages can contain all kinds of bad stuff.
Artur Meinild
  • 31,035
Adobe Flash player has ended support in like January 2021 but you don't really need it anymore as we are using something better that is HTML5.
Flash player can not be download anymore and most web browsers now stop support for Flash player so even if you could install it. It would be a waste of space on your drive and a waste of time.
Flash player has ended support because most websites stopped using it and it was a security issue. We also had to download Flash player.
HTML5 is preinstalled on your web browser and has better security. Most websites uses HTML5 now. But I do believe there is an alternative that allows you to play Flash games but not too sure.
Read more about the flash player end of life.
Hope this helps anyone that is having the same issue.
Artur Meinild
  • 31,035
Jon
  • 81
It is still possible to use Flash on selected websites, if you are able to find the Flash plugin itself anywhere on the Net, which can be hard, because it has been removed from all the usual places it was available to download from.
You need three things (at least that's what I use myself):
  1. Firefox version no higher than 84 (install a separate instance of Firefox from your main browser into a separate directory)
  2. the Flash plugin itself
  3. a configuration file /etc/adobe/mms.cfg specifying URLs where use of Flash is allowed
I have written more about this here: What possibilities to use Flash will be there after EOL?
Also note: if you manage to find and install Flash plugin, don't let the system update it as "update" will actually uninstall the plugin. You may consider to lock the package version (eg. using Synaptic) to avoid update.
Also, if you can just download .swf file to your computer and run it locally, Adobe standalone Flash Player (aka Flash Player Projector) can still be downloaded and it does the job: https://www.adobe.com/support/flashplayer/debug_downloads.html
raj
  • 11,409
-2
None of the current answers actually attempt to answer the question. It is apparently possible to still use Flash with Pale Moon browser by installing through Wine from a third party. I have not tried it and use at your own risk.
http://www.microjogos.com/palemoon.php
https://archive.org/details/flashplayerarchive
qwr
  • 2,969
