I am not able to install mysql workbench on ubuntu 18.04. There is some dependency error. Following are the commands I have tried and their outputs
sudo apt install mysql-workbench
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: mysql-workbench : Depends: gdal-abi-2-2-3 Depends: libgdal20 (>= 2.0.1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
sudo apt --fix-broken install
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
sudo apt-get dist-upgrade
Calculating upgrade... Done
The following packages have been kept back:
  libodbc1 wine-stable
sudo apt-get install -f
sudo apt-get autoremove
These commands gave no output
dpkg --get-selections | grep hold`
sudo dpkg --configure -a
apt-mark showhold
I also tried using aptitude instead of apt. I used synaptic package manager. Edit -> Fix Broken Packages. It shows "Successfully fixed dependency problems" at the bottom but problem still not solved.
Edit: I ran this command
apt-cache policy mysql-workbench
Output
mysql-workbench:
  Installed: (none)
  Candidate: 6.3.8+dfsg-1build3
  Version table:
     6.3.8+dfsg-1build3 500
        500 http://in.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
Edit2: I ran this command
apt-cache policy gdal-abi-2-2-3 libgdal20
Output
gdal-abi-2-2-3:
  Installed: (none)
  Candidate: (none)
  Version table:
libgdal20:
  Installed: (none)
  Candidate: 2.2.3+dfsg-2
  Version table:
     2.2.3+dfsg-2 500
Edit3 I ran this command
sudo apt install libgdal20
Output
The following packages have unmet dependencies: libgdal20 : Depends: libarmadillo8 but it is not going to be installed Depends: libhdf5-100 but it is not going to be installed Depends: libnetcdf13 (>= 4.0.1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
If I try to install any of the dependencies, the same error shows up again telling their dependencies. But isn't apt supposed to install all the dependencies on its own?
Edit 4: I ran this command
gedit /etc/apt/sources.list
Output https://paste.ubuntu.com/p/VncCrpPNHY/
Edit 5 I tried installing it with synaptic package manager. On clicking apply after marking mysql-workbench for installation, I got a dialogue box that says
Could not apply changes. Fix broken packages first.
On going to Edit -> Fix Broken Packages, I get a dialogue box that says
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
However if I just open synaptic and do Edit -> fix broken packages without marking MySQL workbench for installation, it says at the bottom "successfully fixed dependency problems".
I ran
sudo apt update
Output
Hit:1 http://packages.microsoft.com/repos/code stable InRelease
Hit:2 http://in.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:4 http://ppa.launchpad.net/linuxuprising/java/ubuntu bionic InRelease
Hit:5 https://packages.microsoft.com/ubuntu/18.04/prod bionic InRelease
Hit:6 https://repo.skype.com/deb stable InRelease
Hit:7 https://debrepo.freedownloadmanager.org bionic InRelease
1 package can be upgraded. Run 'apt list --upgradable' to see it.
I ran
sudo apt list --upgradable
Output
Listing... Done
libodbc1/bionic 2.3.7 amd64 [upgradable from: 2.3.4-1.1ubuntu3]
N: There is 1 additional version. Please use the '-a' switch to see it
I ran the above command with -a switch
sudo apt list --upgradable -a
Output
Listing... Done
libodbc1/bionic,now 2.3.4-1.1ubuntu3 amd64 [installed,upgradable to: 2.3.7]
