The laptop does not suspend when suspend key is pressed, it is not suspended even when I type
command systemctl suspend -i .
One of the usb ports does not work and usb2-port3 over-current condition message comes at dmesg.
  • OS: Ubuntu 20.04 ;
  • HW: DELL Latitude
The laptop successfully goes to sleep in Windows 10 mode(dual boot).
Following is the journalctl log regarding suspend
    May 30 01:34:27 user_abcd kernel: PM: suspend entry (deep)
    May 30 01:34:33 user_abcd kernel: printk: Suspending console(s) (use no_console_suspend to debug)
    May 30 01:34:33 user_abcd kernel: PM: dpm_run_callback(): usb_dev_suspend+0x0/0x20 returns -16
    May 30 01:34:33 user_abcd kernel: PM: Device usb2 failed to suspend async: error -16
    May 30 01:34:33 user_abcd kernel: PM: Device usb1 failed to suspend async: error -16
    May 30 01:34:33 user_abcd kernel: PM: Some devices failed to suspend, or early wake event detected
    May 30 01:34:33 user_abcd kernel: PM: suspend exit
    May 30 01:34:33 user_abcd kernel: PM: suspend entry (s2idle)
    May 30 01:34:38 user_abcd kernel: printk: Suspending console(s) (use no_console_suspend to debug)
    May 30 01:34:38 user_abcd kernel: PM: dpm_run_callback(): usb_dev_suspend+0x0/0x20 returns -16
    May 30 01:34:38 user_abcd kernel: PM: Device usb2 failed to suspend async: error -16
    May 30 01:34:38 user_abcd kernel: PM: Device usb1 failed to suspend async: error -16
    May 30 01:34:38 user_abcd kernel: PM: Some devices failed to suspend, or early wake event detected
    May 30 01:34:39 user_abcd kernel: PM: suspend exit
    May 30 01:34:38 user_abcd systemd-sleep[2322]: Failed to suspend system. System resumed again: Device or resource busy
    May 30 01:34:39 user_abcd systemd[1]: systemd-suspend.service: Main process exited, code=exited, status=1/FAILURE
    May 30 01:34:39 user_abcd systemd[1]: systemd-suspend.service: Failed with result 'exit-code'.
    May 30 01:34:39 user_abcd systemd[1]: suspend.target: Job suspend.target/start failed with result 'dependency'.
lsusb output:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0cf3:e007 Qualcomm Atheros Communications
Bus 001 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 002: ID 0bda:5769 Realtek Semiconductor Corp. Integrated_Webcam_HD
Rohit Gupta
  • 348
A B
  • 41
