I just installed Ubuntu 20.04 on an UX31A Notebook Asus laptop.
The Wi-fi worked the first 2 minutes then shut down. I can't relaunch it and get the error message: "No Wi-Fi Adapter Found"
I tried:
- Re-installing the Wi-Fi driver through the ubuntu iso. But there are no additional drivers to install
- Disabling secure boot mode
- A lot of random things found in various threads
- fn+F2 only enables/disables the airplane mode, it has no impact on the wi-fi
- Checked parameters in BIOS, wi-fi is not blocked
This is the output of a few diagnostic commands
$ sudo lshw -C network
*-network DISABLED
description: Wireless interface
product: Centrino Advanced-N 6235
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 24
serial: c4:85:08:aa:c5:94
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.8.0-53-generic firmware=18.168.6.1 6000g2b-6.ucode latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:32 memory:f7c00000-f7c01fff
$ rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
$ sudo dmesg | grep wlp
[4.565003] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
$ sudo dmesg | grep iwl
[ 4.166969] iwlwifi 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 4.242244] iwlwifi 0000:02:00.0: loaded firmware version 18.168.6.1 6000g2b-6.ucode op_mode iwldvm
[ 4.242290] iwlwifi 0000:02:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 4.290348] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 4.290351] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 4.290352] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[ 4.290355] iwlwifi 0000:02:00.0: Detected Intel(R) Centrino(R) Advanced-N 6235 AGN, REV=0xB0
[ 4.302808] iwlwifi 0000:02:00.0: reporting RF_KILL (radio disabled)
[ 4.302832] iwlwifi 0000:02:00.0: RF_KILL bit toggled to disable radio.
[ 4.323905] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 4.565003] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[ 377.942252] iwlwifi 0000:02:00.0: RF_KILL bit toggled to disable radio.
$ lsmod | grep -e asus -e wmi
snd_rawmidi 36864 1 snd_seq_midi
snd_seq_device 16384 3 snd_seq,snd_seq_midi,snd_rawmidi
asus_nb_wmi 32768 0
asus_wmi 36864 1 asus_nb_wmi
sparse_keymap 16384 1 asus_wmi
snd 94208 17 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
asus_wireless 20480 0
wmi 32768 1 asus_wmi
video 49152 2 asus_wmi,i915
After I run sudo modprobe -r asus-wireless, fn+f2 no longer enables/disables airplane mode but it doesn't change the wi-fi status.
$ lspci -nnk | grep -i -A2 net
02:00.0 Network controller [0280]: Intel Corporation Centrino Advanced-N 6235 [8086:088e] (rev 24)
Subsystem: Intel Corporation Centrino Advanced-N 6235 AGN [8086:4060]
Kernel driver in use: iwlwifi
$ sudo ip link set wlp2s0 up
RTNETLINK answers: Operation not possible due to RF-kill
$ ethtool -i wlp2s0
driver: iwlwifi
version: 5.8.0-53-generic
firmware-version: 18.168.6.1 6000g2b-6.ucode
expansion-rom-version:
bus-info: 0000:02:00.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
$ service network-manager status
● NetworkManager.service - Network Manager
Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2021-05-30 12:33:51 CEST; 14min ago
Docs: man:NetworkManager(8)
Main PID: 625 (NetworkManager)
Tasks: 3 (limit: 4516)
Memory: 14.3M
CGroup: /system.slice/NetworkManager.service
└─625 /usr/sbin/NetworkManager --no-daemon
NetworkManager[625]: <info> [1622371477.9664] dhcp4 (enx9cebe80f5ca5): state changed unknown -> bound
NetworkManager[625]: <info> [1622371477.9722] device (enx9cebe80f5ca5): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
NetworkManager[625]: <info> [1622371477.9883] device (enx9cebe80f5ca5): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
NetworkManager[625]: <info> [1622371477.9887] device (enx9cebe80f5ca5): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
NetworkManager[625]: <info> [1622371477.9894] manager: NetworkManager state is now CONNECTED_LOCAL
NetworkManager[625]: <info> [1622371477.9911] manager: NetworkManager state is now CONNECTED_SITE
NetworkManager[625]: <info> [1622371477.9913] policy: set 'Connexion filaire 1' (enx9cebe80f5ca5) as default for IPv4 routing and DNS
NetworkManager[625]: <info> [1622371477.9923] device (enx9cebe80f5ca5): Activation: successful, device activated.
NetworkManager[625]: <info> [1622371478.2308] manager: NetworkManager state is now CONNECTED_GLOBAL
NetworkManager[625]: <info> [1622371487.3372] audit: op="radio-control" arg="wireless-enabled" pid=2255 uid=1000 result="success"
$ uname -a
Linux XXX-UX31A 5.8.0-53-generic #60~20.04.1-Ubuntu SMP Thu May 6 09:52:46 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
hardinfo Comupter -> Kernel Modules:
Kernel Modules
Loaded Modules
rfcomm Bluetooth RFCOMM ver 1.11
cmac CMAC keyed hash algorithm
algif_hash
algif_skcipher
af_alg
bnep Bluetooth BNEP ver 1.3
snd_hda_codec_hdmi HDMI HD-audio codec
snd_hda_codec_realtek Realtek HD-audio codec
snd_hda_codec_generic Generic HD-audio codec parser
ledtrig_audio LED trigger for audio mute control
nls_iso8859_1
intel_rapl_msr Driver for Intel RAPL (Running Average Power Limit) control via MSR interface
snd_hda_intel Intel HDA driver
snd_intel_dspcfg Intel DSP config driver
snd_hda_codec HDA codec core
snd_hda_core HD-audio bus
snd_hwdep Hardware dependent layer
mei_hdcp MEI HDCP
snd_pcm Midlevel PCM code for ALSA.
uvcvideo USB Video Class driver
videobuf2_vmalloc vmalloc memory handling routines for videobuf2
intel_rapl_common Intel Runtime Average Power Limit (RAPL) common code
videobuf2_memops common memory handling routines for videobuf2
snd_seq_midi Advanced Linux Sound Architecture sequencer MIDI synth.
x86_pkg_temp_thermal X86 PKG TEMP Thermal Driver
snd_seq_midi_event MIDI byte <-> sequencer event coder
videobuf2_v4l2 Driver helper framework for Video for Linux 2
intel_powerclamp Package Level C-state Idle Injection for Intel CPUs
snd_rawmidi Midlevel RawMidi code for ALSA.
rtsx_usb_ms Realtek USB Memstick Card Host Driver
coretemp Intel Core temperature monitor
videobuf2_common Media buffer core framework
kvm_intel
iwldvm Intel(R) Wireless WiFi Link AGN driver for Linux
memstick Sony MemoryStick core driver
kvm
videodev Video4Linux2 core driver
snd_seq Advanced Linux Sound Architecture sequencer.
mac80211 IEEE 802.11 subsystem
asix ASIX AX8817X based USB 2.0 Ethernet Devices
btusb Generic Bluetooth USB driver ver 0.8
usbnet USB network driver framework
btrtl Bluetooth support for Realtek devices ver 0.1
btbcm Bluetooth support for Broadcom devices ver 0.1
mii MII hardware support library
crct10dif_pclmul T10 DIF CRC calculation accelerated with PCLMULQDQ.
libarc4
btintel Bluetooth support for Intel devices ver 0.1
snd_seq_device ALSA sequencer device management
mc Device node registration for media drivers
bluetooth Bluetooth Core ver 2.22
ghash_clmulni_intel GHASH hash function, accelerated by PCLMULQDQ-NI
aesni_intel Rijndael (AES) Cipher Algorithm, Intel AES-NI instructions optimized
iwlwifi Intel(R) Wireless WiFi driver for Linux
ecdh_generic ECDH generic algorithm
asus_nb_wmi Asus Notebooks WMI Hotkey Driver
ecc
crypto_simd
snd_timer ALSA timer interface
asus_wmi Asus Generic WMI Driver
joydev Joystick device interfaces
cryptd Software async crypto daemon
sparse_keymap Generic support for sparse keymaps
glue_helper
rapl
i915 Intel Graphics
snd Advanced Linux Sound Architecture driver for soundcards.
intel_cstate
input_leds Input -> LEDs Bridge
cfg80211 wireless configuration support
efi_pstore EFI variable backend for pstore
serio_raw Raw serio driver
drm_kms_helper DRM KMS helper
soundcore Core sound module
cec Device node registration for cec drivers
rc_core
i2c_algo_bit I2C-Bus bit-banging algorithm
mei_me Intel(R) Management Engine Interface
fb_sys_fops Generic file read (fb in system RAM)
syscopyarea Generic copyarea (sys-to-sys)
sysfillrect Generic fill rectangle (sys-to-sys)
sysimgblt 1-bit/8-bit to 1-32 bit color expansion (sys-to-sys)
mei Intel(R) Management Engine Interface
acpi_als ACPI Ambient Light Sensor Driver
mac_hid
kfifo_buf
int3400_thermal INT3400 Thermal driver
acpi_thermal_rel Intel acpi thermal rel misc dev driver
industrialio Industrial I/O core
int3403_thermal ACPI INT3403 thermal driver
asus_wireless Asus Wireless Radio Control Driver
int3402_thermal INT3402 Thermal driver
int340x_thermal_zone Intel INT340x common thermal zone handler
sch_fq_codel Fair Queue CoDel discipline
parport_pc PC-style parallel port driver
ppdev
lp
parport
drm DRM shared core routines
ip_tables IPv4 packet filter
x_tables {ip,ip6,arp,eb}_tables backend module
autofs4
rtsx_usb_sdmmc Realtek USB SD/MMC Card Host Driver
rtsx_usb Realtek USB Card Reader Driver
xhci_pci xHCI PCI Host Controller Driver
psmouse PS/2 mouse driver
lpc_ich LPC interface for Intel ICH
xhci_pci_renesas
ahci AHCI SATA low-level driver
libahci Common AHCI SATA low-level routines
i2c_i801 I801 SMBus driver
crc32_pclmul
i2c_smbus SMBus protocol extensions support
wmi ACPI-WMI Mapping Driver
video ACPI Video Driver
Network -> Intergaces -> wlp2s0:
Network Adapter properties
Interface Type Wireless
Hardware Adress (MAC) : XX:XX:XX:XX:XX (hidden)
MTU 1500
Transfer Details:
Bytes received 0 (0.00 MIB)
Bytes transferred 0 (0.00 MIB)
Devices -> PCIDevices -> Network:
PCI Devices
Host bridge Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
VGA compatible controller Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09) (prog-if 00 [VGA controller])
Signal processing controller Intel Corporation 3rd Gen Core Processor Thermal Subsystem (rev 09)
USB controller Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04) (prog-if 30 [XHCI])
Communication controller Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
USB controller Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04) (prog-if 20 [EHCI])
Audio device Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
PCI bridge Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4) (prog-if 00 [Normal decode])
PCI bridge Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4) (prog-if 00 [Normal decode])
USB controller Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04) (prog-if 20 [EHCI])
ISA bridge Intel Corporation HM76 Express Chipset LPC Controller (rev 04)
SATA controller Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
SMBus Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
Signal processing controller Intel Corporation 7 Series/C210 Series Chipset Family Thermal Management Controller (rev 04)
Network controller Intel Corporation Centrino Advanced-N 6235 (rev 24)
$ ls -al /etc/modprobe.d
total 56
drwxr-xr-x 2 root root 4096 févr. 9 19:51 .
drwxr-xr-x 129 root root 12288 juin 3 21:51 ..
-rw-r--r-- 1 root root 2507 juil. 31 2015 alsa-base.conf
-rw-r--r-- 1 root root 154 févr. 16 2020 amd64-microcode-blacklist.conf
-rw-r--r-- 1 root root 325 mars 12 2020 blacklist-ath_pci.conf
-rw-r--r-- 1 root root 1518 mars 12 2020 blacklist.conf
-rw-r--r-- 1 root root 210 mars 12 2020 blacklist-firewire.conf
-rw-r--r-- 1 root root 677 mars 12 2020 blacklist-framebuffer.conf
-rw-r--r-- 1 root root 156 juil. 31 2015 blacklist-modem.conf
lrwxrwxrwx 1 root root 41 juin 2 22:59 blacklist-oss.conf -> /lib/linux-sound-base/noOSS.modprobe.conf
-rw-r--r-- 1 root root 583 mars 12 2020 blacklist-rare-network.conf
-rw-r--r-- 1 root root 154 nov. 12 2020 intel-microcode-blacklist.conf
-rw-r--r-- 1 root root 347 mars 12 2020 iwlwifi.conf
$cat /etc/modprobe.d/modprobe.conf
cat: /etc/modprobe.d/modprobe.conf: No such file or directory
$cat /etc/modprobe.d/iwlwifi.conf
# /etc/modprobe.d/iwlwifi.conf
# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
# microcode file installed on the system. When removing iwlwifi, first
# remove the iwl?vm module and then iwlwifi.
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
$cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-5.8.0-53-generic root=UUID=a3725b5e-92ec-415b-87c6-e8d2a326cc17 ro quiet splash vt.handoff=7
$modinfo iwlwifi
filename: /lib/modules/5.8.0-53-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Intel Corporation <linuxwifi@intel.com>
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-56.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-56.ucode
firmware: iwlwifi-ty-a0-gf-a0-56.ucode
firmware: iwlwifi-so-a0-gf-a0-56.ucode
firmware: iwlwifi-so-a0-hr-b0-56.ucode
firmware: iwlwifi-so-a0-jf-b0-56.ucode
firmware: iwlwifi-cc-a0-56.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-56.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-56.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-56.ucode
firmware: iwlwifi-Qu-b0-jf-b0-56.ucode
firmware: iwlwifi-Qu-c0-hr-b0-56.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-56.ucode
firmware: iwlwifi-Qu-b0-hr-b0-56.ucode
srcversion: F1C209D24ECAFDEE75AF058
alias: pci:v00008086d00007AF0sv*sd00000A10bc*sc*i*
[bunch of aliases]
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 5.8.0-53-generic SMP mod_unload modversions
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 35:38:57:EC:63:07:C2:02:DE:90:95:7A:ED:63:B0:27:D4:D0:8A:A6
sig_hashalgo: sha512
signature: 63:F9:F1:24:1D:2E:5B:61:21:0D:34:0C:02:E5:29:91:94:71:B7:60:
77:5C:44:DF:D9:07:4E:F2:0A:BC:3D:45:3C:E0:CC:EC:02:2B:24:44:
37:93:15:04:75:DE:25:3E:99:06:33:1A:F4:21:61:7D:57:6B:A1:A5:
67:E9:2A:79:7B:C3:EA:8E:AC:26:E9:F8:2A:A0:61:73:1C:00:5D:AF:
B9:97:76:FB:DC:77:6F:98:F7:A4:E4:EA:CB:04:3A:30:B6:7A:B4:09:
AF:A7:F4:A1:BE:FA:76:1C:66:30:99:EB:D8:82:8A:86:D6:79:07:93:
BF:B1:24:D3:6C:E3:26:FA:C1:48:8C:43:04:56:3E:6D:3B:19:BD:B2:
82:65:D5:E2:A0:BC:3D:F9:8C:1C:2C:D5:D1:00:CD:04:E8:28:98:75:
F5:9C:EE:58:93:9F:59:90:60:77:AF:AE:3F:02:0B:19:5A:CE:4C:72:
E7:BE:D7:0A:20:04:2A:CD:26:3F:1A:5A:16:BC:ED:DA:B6:6C:40:AC:
5B:97:22:46:07:09:04:82:22:8C:DD:27:8A:B4:19:F6:2D:1A:ED:CA:
F2:6A:1C:B8:5D:14:DB:D9:F0:30:75:D8:CC:3D:70:CA:21:53:1A:E6:
7B:5A:C3:AB:D6:0D:EB:C5:EA:E5:C7:AB:A4:C4:81:A2:DB:47:0A:15:
20:91:0C:36:36:05:DB:93:54:32:6D:6C:F3:B7:88:F9:12:DB:76:62:
1E:B9:3F:1B:4F:47:14:28:28:80:15:83:72:67:DC:82:0B:9E:09:3E:
A6:78:2C:DD:BE:85:75:8A:9A:06:3E:09:B2:7C:67:E6:73:AD:9D:83:
C7:49:3B:84:53:E4:40:E5:B8:6B:89:56:27:97:AF:35:43:70:12:6F:
B9:5E:DF:D3:18:6C:29:F6:3D:6C:4C:F3:6D:52:D6:51:65:8F:FD:30:
C8:AF:43:C2:33:35:94:F4:64:CA:5C:80:05:09:AA:46:D8:67:AC:7F:
CC:5A:F9:1C:CF:78:C1:A0:16:46:F4:63:1E:72:B8:81:A2:0C:51:F7:
E3:6E:C2:5E:F6:A3:18:61:21:5B:4F:56:39:0C:BA:30:4C:C3:CF:2A:
E7:4F:1D:48:0F:5B:6D:62:B7:2F:11:6A:DC:63:E0:18:E8:39:FB:99:
5F:3E:3C:FB:11:FE:CE:4C:52:F0:D8:8C:80:A7:B6:C0:0C:2C:F0:0F:
8B:7F:CC:F5:B5:DD:4C:D4:8C:00:23:56:D1:93:03:CE:F1:E8:22:89:
08:3F:E1:00:C4:B5:6F:9C:5D:30:6D:C0:B3:65:48:62:EA:86:03:AF:
91:F7:EA:30:77:4E:A5:B5:D5:50:F3:68
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:Enable debug INI TLV FW debug infrastructure (default: true (bool)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
$ ls -al &(locate rfkill |grep service)
[1] 45522
total 80
drwxr-xr-x 15 francois francois 4096 juin 3 21:58 .
drwxr-xr-x 3 root root 4096 juin 2 23:03 ..
-rw------- 1 francois francois 605 juin 4 22:03 .bash_history
-rw-r--r-- 1 francois francois 220 juin 2 23:03 .bash_logout
-rw-r--r-- 1 francois francois 3771 juin 2 23:03 .bashrc
drwxr-xr-x 2 francois francois 4096 juin 2 23:10 Bureau
drwx------ 13 francois francois 4096 juin 3 21:58 .cache
drwx------ 11 francois francois 4096 juin 3 21:58 .config
drwxr-xr-x 2 francois francois 4096 juin 2 23:10 Documents
drwx------ 3 francois francois 4096 juin 2 23:10 .gnupg
drwxr-xr-x 2 francois francois 4096 juin 2 23:10 Images
drwxr-xr-x 3 francois francois 4096 juin 2 23:10 .local
drwxr-xr-x 2 francois francois 4096 juin 2 23:10 Modèles
drwx------ 5 francois francois 4096 juin 2 23:10 .mozilla
drwxr-xr-x 2 francois francois 4096 juin 2 23:10 Musique
-rw-r--r-- 1 francois francois 357 juin 3 21:53 .pam_environment
-rw-r--r-- 1 francois francois 807 juin 2 23:03 .profile
drwxr-xr-x 2 francois francois 4096 juin 2 23:10 Public
-rw-r--r-- 1 francois francois 0 juin 3 21:58 .sudo_as_admin_successful
drwxr-xr-x 2 francois francois 4096 juin 2 23:10 Téléchargements
drwxr-xr-x 2 francois francois 4096 juin 2 23:10 Vidéos
/snap/core18/1988/lib/systemd/system/systemd-rfkill.service
/snap/core18/2066/lib/systemd/system/systemd-rfkill.service
/usr/lib/systemd/system/systemd-rfkill.service
/usr/lib/systemd/user/gsd-rfkill.service
/usr/share/man/man8/systemd-rfkill.service.8.gz
[1]+ Done ls --color=auto -al
Does anybody have an idea on how to enable the network ?
Thanks for your help !
