Coders and all,
I have a very similar problem to the one listed in this link below:
Ubuntu 18.04 & Intel HD Graphics 530
I have about 10 donated HP 400 AIO's. They have the same specs as the above link and lshw displays the same hardware listing. As the user was able to get Ubuntu to install and boot using nomodest setting in /etc/default/grub. I was able to install Xubuntu 20.04.2 I additionally set the GLX switches to display 1600X900. After logging in, and after a few minutes, the desktop locks up. The pointer works moves but no other input is accepted. I can successfully perform cntrl alt f1 and login. So the whole system is not crippled, but the gui is unusable. I followed the steps advised in the links above, except to attempt to install the software on the intel web site. I figured that it is no long current. Just attempting to verify that and glean from my fellow travelers some more in debth troubleshooting steps I might be able to implement.
Regards in Advance,
Couch_Potato
Edit:
[ 5628.956] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5628.957] (==) No Layout section. Using the first Screen section.
[ 5628.957] (==) No screen section available. Using defaults.
[ 5628.957] (**) |-->Screen "Default Screen Section" (0)
[ 5628.957] (**) | |-->Monitor "<default monitor>"
[ 5628.957] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 5628.957] (==) Automatically adding devices
[ 5628.957] (==) Automatically enabling devices
[ 5628.957] (==) Automatically adding GPU devices
[ 5628.957] (==) Automatically binding GPU devices
[ 5628.957] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5628.957] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 5628.957] Entry deleted from font path.
[ 5628.957] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 5628.957] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 5628.957] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 5628.957] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 5628.957] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 5628.957] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 5628.957] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 5628.957] (II) Loader magic: 0x56443d13e020
[ 5628.957] (II) Module ABI versions:
[ 5628.957] X.Org ANSI C Emulation: 0.4
[ 5628.957] X.Org Video Driver: 24.1
[ 5628.957] X.Org XInput driver : 24.1
[ 5628.957] X.Org Server Extension : 10.0
[ 5628.959] (++) using VT number 8
[ 5628.959] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 5628.962] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 5628.962] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[ 5628.967] (--) PCI:(0@0:2:0) 8086:0126:1028:0492 rev 9, Mem @ 0xe1400000/4194304, 0xd0000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 5628.967] (II) LoadModule: "glx"
[ 5628.967] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5628.968] (II) Module glx: vendor="X.Org Foundation"
[ 5628.968] compiled for 1.20.8, module version = 1.0.0
[ 5628.968] ABI class: X.Org Server Extension, version 10.0
[ 5628.968] (==) Matched modesetting as autoconfigured driver 0
[ 5628.968] (==) Matched fbdev as autoconfigured driver 1
[ 5628.968] (==) Matched vesa as autoconfigured driver 2
[ 5628.968] (==) Assigned the driver to the xf86ConfigLayout
[ 5628.968] (II) LoadModule: "modesetting"
[ 5628.968] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 5628.968] (II) Module modesetting: vendor="X.Org Foundation"
[ 5628.968] compiled for 1.20.8, module version = 1.20.8
[ 5628.968] Module class: X.Org Video Driver
[ 5628.968] ABI class: X.Org Video Driver, version 24.1
[ 5628.968] (II) LoadModule: "fbdev"
[ 5628.968] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 5628.968] (II) Module fbdev: vendor="X.Org Foundation"
[ 5628.968] compiled for 1.20.1, module version = 0.5.0
[ 5628.968] ABI class: X.Org Video Driver, version 24.0
[ 5628.968] (II) LoadModule: "vesa"
[ 5628.968] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 5628.968] (II) Module vesa: vendor="X.Org Foundation"
[ 5628.968] compiled for 1.20.4, module version = 2.4.0
[ 5628.968] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 5628.968] (II) FBDEV: driver for framebuffer: fbdev
[ 5628.968] (II) VESA: driver for VESA chipsets: vesa
[ 5629.344] (*) modeset(0): claimed PCI slot 0@0:2:0
[ 5629.344] (II) modeset(0): using default device
[ 5629.344] (WW) Falling back to old probe method for fbdev
[ 5629.344] (II) Loading sub module "fbdevhw"
[ 5629.344] (II) LoadModule: "fbdevhw"
[ 5629.344] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 5629.344] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 5629.344] compiled for 1.20.8, module version = 0.0.2
[ 5629.344] ABI class: X.Org Video Driver, version 24.1
[ 5629.345] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 5629.345] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 5629.345] (==) modeset(0): RGB weight 888
[ 5629.345] (==) modeset(0): Default visual is TrueColor
[ 5629.345] (II) Loading sub module "glamoregl"
[ 5629.345] (II) LoadModule: "glamoregl"
[ 5629.345] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 5629.349] (II) Module glamoregl: vendor="X.Org Foundation"
[ 5629.349] compiled for 1.20.8, module version = 1.0.1
[ 5629.349] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5629.376] (II) modeset(0): glamor X acceleration enabled on Mesa DRI Intel(R) HD Graphics 3000 (SNB GT2)
[ 5629.376] (II) modeset(0): glamor initialized
[ 5629.376] (II) modeset(0): Output LVDS-1 has no monitor section
[ 5629.377] (II) modeset(0): Output VGA-1 has no monitor section
[ 5629.378] (II) modeset(0): Output HDMI-1 has no monitor section
[ 5629.379] (II) modeset(0): Output DP-1 has no monitor section
[ 5629.380] (II) modeset(0): Output HDMI-2 has no monitor section
[ 5629.382] (II) modeset(0): Output HDMI-3 has no monitor section
[ 5629.382] (II) modeset(0): Output DP-2 has no monitor section
[ 5629.382] (II) modeset(0): Output DP-3 has no monitor section
[ 5629.382] (II) modeset(0): EDID for output LVDS-1
[ 5629.382] (II) modeset(0): Manufacturer: SEC Model: 5441 Serial#: 0
[ 5629.382] (II) modeset(0): Year: 2010 Week: 0
[ 5629.382] (II) modeset(0): EDID Version: 1.4
[ 5629.382] (II) modeset(0): Digital Display Input
[ 5629.382] (II) modeset(0): 6 bits per channel
[ 5629.382] (II) modeset(0): Digital interface is undefined
[ 5629.382] (II) modeset(0): Max Image Size [cm]: horiz.: 29 vert.: 16
[ 5629.382] (II) modeset(0): Gamma: 2.20
[ 5629.382] (II) modeset(0): No DPMS capabilities specified
[ 5629.382] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 5629.382] (II) modeset(0): First detailed timing is preferred mode
[ 5629.382] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 5629.382] (II) modeset(0): redX: 0.610 redY: 0.340 greenX: 0.330 greenY: 0.550
[ 5629.382] (II) modeset(0): blueX: 0.155 blueY: 0.090 whiteX: 0.313 whiteY: 0.329
[ 5629.382] (II) modeset(0): Manufacturer's mask: 0
[ 5629.382] (II) modeset(0): Supported detailed timing:
[ 5629.382] (II) modeset(0): clock: 76.6 MHz Image Size: 293 x 165 mm
[ 5629.382] (II) modeset(0): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1616 h_border: 0
[ 5629.382] (II) modeset(0): v_active: 768 v_sync: 773 v_sync_end 778 v_blanking: 790 v_border: 0
[ 5629.382] (II) modeset(0): clock: 48.3 MHz Image Size: 293 x 165 mm
[ 5629.382] (II) modeset(0): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1528 h_border: 0
[ 5629.382] (II) modeset(0): XXTNN133AT
[ 5629.382] (II) modeset(0): Unknown vendor-specific block 0
[ 5629.382] (II) modeset(0): EDID (in hex):
[ 5629.382] (II) modeset(0): 00ffffffffffff004ca3415400000000
[ 5629.382] (II) modeset(0): 00140104901d10780a4bc59c57548c27
[ 5629.382] (II) modeset(0): 17505400000001010101010101010101
[ 5629.382] (II) modeset(0): 010101010101eb1d56fa500016303020
[ 5629.382] (II) modeset(0): 550025a51000001adc1256a250001630
[ 5629.382] (II) modeset(0): 3020550025a51000001a000000fe0058
[ 5629.382] (II) modeset(0): 58544e4e8031333341540a2000000000
[ 5629.382] (II) modeset(0): 00004101940000000001010a20200023
[ 5629.382] (II) modeset(0): Printing probed modes for output LVDS-1
The changes I have made: Installed edge kernel (5.8) Added ppa://oibaf/graphics-drivers and updated
[https://paste.ubuntu.com/p/MBpkfyWvZ7/][1]
Can someone provide some feedback.
Tx.
