I'm quite new in the world of Linux and software-raid but I encountered a problem in which I hope you guys can help me.
Few days ago the system was not shutdown properly and when I booted the mdadm software raid wouldn't mount anymore and I got an error which stated that /dev/sdb1 (which is part of my raid 0 array) has a bad superblock. I decided to ignore mounting the since my system doesn't depend on it. So i could login and do some tests.
My array contains two disks (sdb1 and sde1) which are set in RAID0. Both drives are identical.
When i run fsck /dev/sdb1 I get the error that my superblock has more blocks then the physical drive.
$ fsck /dev/sdb1
fsck from util-linux 2.20.1
e2fsck 1.42 (29-Nov-2011)
The filesystem size (according to the superblock) is 488380672 blocks
The physical size of the device is 244190390 blocks
Either the superblock or the partition table is likely to be corrupt!
Abort<y>?
My other drive seemed to be OK, but now I get the following error, i assume it has to do with sdb1 missing
$ fsck /dev/sde1
fsck: fsck.linux_raid_member: not found
fsck: error 2 while executing fsck.linux_raid_member for /dev/sde1
In fdisk all seems to be okay, or at least as they we're before..
$ fdisk -l
Disk /dev/sda: 200.0 GB, 200049647616 bytes
255 heads, 63 sectors/track, 24321 cylinders, total 390721968 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000a091a
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 499711 248832 83 Linux
/dev/sda2 501758 390721535 195109889 5 Extended
/dev/sda5 501760 390721535 195109888 8e Linux LVM
Disk /dev/mapper/Server1-root: 193.6 GB, 193646821376 bytes
255 heads, 63 sectors/track, 23542 cylinders, total 378216448 sectors
Disk identifier: 0x00000000
Disk /dev/mapper/Server1-root doesn't contain a valid partition table
Disk /dev/mapper/Server1-swap_1: 2143 MB, 2143289344 bytes
255 heads, 63 sectors/track, 260 cylinders, total 4186112 sectors
Disk /dev/mapper/Server1-swap_1 doesn't contain a valid partition table
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
78 heads, 63 sectors/track, 397542 cylinders, total 1953525168 sectors
Disk identifier: 0x00000300
/dev/sdb1 2048 1953525167 976761560 fd Linux raid autodetect
Disk /dev/sdc: 1000.2 GB, 1000204886016 bytes
24 heads, 63 sectors/track, 1292014 cylinders, total 1953525168 sectors
/dev/sdc1 2048 1953525167 976761560 83 Linux
WARNING: GPT (GUID Partition Table) detected on '/dev/sdd'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdd: 500.1 GB, 500107862016 bytes
81 heads, 63 sectors/track, 191411 cylinders, total 976773168 sectors
/dev/sdd1 2048 976773167 488385560 83 Linux
WARNING: GPT (GUID Partition Table) detected on '/dev/sde'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sde: 1000.2 GB, 1000204886016 bytes
/dev/sde1 2048 1953525167 976761560 fd Linux raid autodetect
When i run dumpe2fs /dev/sdb1 i get:
dumpe2fs 1.42 (29-Nov-2011)
Filesystem volume name: <none>
Last mounted on: /media/raid0
Filesystem UUID: 52e0e3eb-40d7-49fa-9b35-be6513a782d2
Filesystem magic number: 0xEF53
Filesystem revision #: 1 (dynamic)
Filesystem features: ext_attr resize_inode dir_index filetype extent flex_bg sparse_super large_file huge_file uninit_bg dir_nlink extra_isize
Filesystem flags: signed_directory_hash
Default mount options: (none)
Filesystem state: not clean with errors
Errors behavior: Continue
Filesystem OS type: Linux
Inode count: 122101760
Block count: 488380672
Reserved block count: 4883806
Free blocks: 166355414
Free inodes: 121871448
First block: 0
Block size: 4096
Fragment size: 4096
Reserved GDT blocks: 907
Blocks per group: 32768
Fragments per group: 32768
Inodes per group: 8192
Inode blocks per group: 512
RAID stride: 128
RAID stripe width: 256
Flex block group size: 16
Filesystem created: Sun Apr 22 21:57:36 2012
Last mount time: Thu May 3 00:01:08 2012
Last write time: Tue May 8 20:33:15 2012
Mount count: 24
Maximum mount count: 35
Last checked: Sun Apr 22 21:57:36 2012
Check interval: 15552000 (6 months)
Next check after: Fri Oct 19 21:57:36 2012
Lifetime writes: 1809 GB
Reserved blocks uid: 0 (user root)
Reserved blocks gid: 0 (group root)
First inode: 11
Inode size: 256
Required extra isize: 28
Desired extra isize: 28
Default directory hash: half_md4
Directory Hash Seed: 54b59b52-4cfc-4bea-8c5a-5fc730317f4f
Journal backup: inode blocks
And a whole bunch of these:
Group 0: (Blocks 0-32767) [ITABLE_ZEROED]
Checksum 0x6848, unused inodes 0
Primary superblock at 0, Group descriptors at 1-117
Reserved GDT blocks at 118-1024
Block bitmap at 1025 (+1025), Inode bitmap at 1041 (+1041)
Inode table at 1057-1568 (+1057)
23517 free blocks, 8182 free inodes, 1 directories
When i run cat /proc/mdstat i get:
Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10]
md0 : inactive sdb[0](S)
976761560 blocks super 1.2
md127 : inactive sde1[1](S)
976760536 blocks super 1.2
unused devices: <none>
So all of the sudden I have two raid arrays now...
I've tried the method mentioned in this topic where they suggest to use backup sectors. But no luck, the error about a superblock larger then the physical drive persists.
Can you guys help me? I'm quite scared I lost my data now..
Edit: contents of mdadm.conf file added
# mdadm.conf
# Please refer to mdadm.conf(5) for information about this file.
# by default (built-in), scan all partitions (/proc/partitions) and all
# containers for MD superblocks. alternatively, specify devices to scan, using
# wildcards if desired.
#DEVICE partitions containers
# auto-create devices with Debian standard permissions
CREATE owner=root group=disk mode=0660 auto=yes
# automatically tag new arrays as belonging to the local system
HOMEHOST <system>
# instruct the monitoring daemon where to send mail alerts
# MAILADDR
# definitions of existing MD arrays
#ARRAY /dev/md/0 metadata=1.2 UUID=7658dc76:c33da511:d40c5dee:c5d5143d name=Server1:0
# This file was auto-generated on Fri, 27 Apr 2012 18:38:03 +0200
# by mkconf $Id$
ARRAY /dev/md/0 metadata=1.2 UUID=3720f7a5:ae73fb52:deee0813:677105ae name=Server1:0
