I have dual graphics Intel 520 integrated and nVidia 930MX dedicated. I'm running 20.04.2 and installed nvidia-driver-460 through Additional Drivers, and intel-media-va-driver-non-free through terminal. Currently I'm only getting display (and successful boot) on intel GPU. After I run sudo prime-select nvidia and reboot, I'm no longer able to boot, and have to revert to intel through TTY. Running nvidia-smi gives following error:
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
The nvidia-xconfig generates a xorg.conf in which the 'Files' section is empty.
nvidia-settings gives error:
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
(nvidia-settings:10549): GLib-GObject-CRITICAL **: 18:16:11.739: g_object_unref: assertion
'G_IS_OBJECT (object)' failed
** Message: 18:16:11.749: PRIME: Requires offloading
** Message: 18:16:11.749: PRIME: is it supported? yes
** Message: 18:16:11.857: PRIME: Usage: /usr/bin/prime-select nvidia|intel|on-demand|query
** Message: 18:16:11.857: PRIME: on-demand mode: "1"
** Message: 18:16:11.857: PRIME: is "on-demand" mode supported? yes
Running whereis nvidia gives:
nvidia: /usr/lib/x86_64-linux-gnu/nvidia /usr/lib/nvidia /usr/share/nvidia /usr/src/nvidia-460.73.01/nvidia
So driver is installed but not loading. How to get the driver working? I'd like to retain intel as well.
EDIT: running sudo prime-select nvidia, reboot with nomodeset, then running nvidia-smi from TTY (because there is no GUI) gives following output:
Tue May 25 18:33:17 2021
| NVIDIA-SMI 460.73.01 Driver Version: 460.73.01 CUDA Version: 11.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce 930MX Off | 00000000:01:00.0 Off | N/A |
| N/A 39C P8 N/A / N/A | 10MiB / 2004MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1063 G /usr/lib/xorg/Xorg 6MiB |
| 0 N/A N/A 1292 G /usr/bin/gnome-shell 2MiB |
That shows nvidia driver is loading and working, but why the GUI isn't working is beyond me.
EDIT 2: running nvidia-settings and selecting any graphics from PRIME profiles results in Segmentation fault.
