I installed Lubuntu 12.04 via USB-stick on my EEE PC 1005HA. It booted fine from the hdd with the USB plugged in. If I remove the USB it won't boot from the hdd. When I plug the USB back in, it boots from the hdd just fine but it won't let me boot from the stick even when I select it in the BIOS. I've never experienced something like this. Without the USB plugged in, I just get a blinking underscore and that's it.
Alvar
  • 17,038
H3R3T1K
  • 2,515
  • 41
  • 69
Arno, this link might lead you to a solution. Good luck.
Can't boot without Flash Drive plugged in
Sun Dial
  • 421
You probably wrote the bootloader to the USB flash drive. Install again and make sure you set the bootloader to be installed on the HDD.
