I am having Ubuntu as a Host machine and Windows VM. The VM is not starting. I need to take some important files from the virtual machine to Host Machine. So is there any way to extract the contents of Windows VM without running it?
P7Zip will open VDI files
  • Install P7Zip-Desktop from Ubuntu Software.
  • Open folder containing VDI file in Nautilus, (Files).
  • Right click VDI file and select Open with Other Application.
  • Select P7Zip Desktop.
  • Double click the VDI file in the P7Zip window.
  • View or extract files as you like.
C.S.Cameron
  • 20,530
  • 78
  • 125
If you are using Windows-10, you can use 7-Zip to extract vdi files.
Its an opensource and free software and very easy to use.
  • Download the software
  • Navigate to the your vdi file.
  • Double click on the vdi file
  • In my case, I saw files like 0.fat, 1.img
  • Check the file type and size to determine which file you want to open.
  • Double click on the file. I double clicked on 1.img because that was my device.
  • Wait for few minutes.
  • When the process is complete, you will see the complete filesystem.
  • Now you can easily copy files to you windows drive.
Cheers,
