I can't install COMODO Antivirus on my laptop. I use Ubuntu 20.04 and this is really weird, but when I run the following command:
sudo dpkg -i cav-linux_x64.deb
it shows this message:
Depends on libssl0.9.8:amd64
I tried to install it, using:
sudo apt-get install libssl0.9.8:amd64
(because my system is amd64) and it returns:
dpkg: erro ao processar o arquivo /var/cache/apt/archives/libssl0.9.8_0.9.8o-7ubuntu3.2.14.04.1_amd64.deb (--unpack):
não foi possível abrir '/lib/x86_64-linux-gnu/libssl.so.0.9.8.dpkg-new': Ficheiro ou pasta inexistente
No apport report written because the error message indicates an issue on the local system
Foram encontrados erros enquanto processava:
I don't know what to do. I tried installing multiarch-support too, because when I tried to install just libssl0.9.8, it said that multiarch-support was a dependency. Can you help me?
P.S.: Sorry for the Portuguese in the command line, I think that just copying could help to solve the problem better than translating:
(A ler a base de dados ... 262033 ficheiros e directórios actualmente instalados.)
A preparar para desempacotar cav-linux_x64.deb ...
A descompactar cav-linux (1.1.268025-1) sobre (1.1.268025-1) ...
Uninstallation succeed!
dpkg: problemas com dependências impedem a configuração de cav-linux:
cav-linux depende de libssl0.9.8 (>= 0.9.8m-1); no entanto:
O pacote libssl0.9.8:amd64 não está instalado.
dpkg: erro ao processar o pacote cav-linux (--install):
problemas com dependências - a deixar por configurar
cav-linux
