When I start anki in my Ubuntu machine, this popups
black screen popup
So I tried starting Anki using terminal, and this is the error it shows.
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Qt warning: QQuickWidget: Failed to make context current
Qt warning: QQuickWidget::resizeEvent() no OpenGL context
Xlib: sequence lost (0x102d1 > 0x2d3) in reply type 0x0!
Xlib: sequence lost (0x102d4 > 0x2d6) in reply type 0x0!
[21404:21447:0520/120313.269102:ERROR:context_group.cc(292)] ContextResult::kFatalFailure: too few texture units supported (0, should be 8).
Qt warning: QQuickWidget: Attempted to render scene with no context
[21461:7:0520/120313.271585:ERROR:command_buffer_proxy_impl.cc(144)] ContextResult::kTransientFailure: Failed to send GpuChannelMsg_CreateCommandBuffer.
[21404:21447:0520/120313.291113:ERROR:context_group.cc(292)] ContextResult::kFatalFailure: too few texture units supported (0, should be 8).
Qt warning: QQuickWidget::invalidateRenderControl could not make context current
Specs
  • OS version - Ubuntu 20.04.2 LTS
  • Graphics - AMD Radeon RX 580 Series
  • Processor - AMD Ryzen 7 3800x 8-core processor × 16
I have tried reinstalling my graphic drivers but it didn't work.
Also I was trying to do this method, but I couldn't as I have very low experience with linux and my graphic card is AMD
I have also tried this, but it doesn't seems to work.
Aathik
If you are using Anki (2.1.54 in my case) with Qt6, try enabling software rendering:
echo software > ~/.local/share/Anki2/gldriver6
daaawx
  • 277
Whenever I encounter error messages about missing drivers / files / shared libraries, I will try to find out which deb package the file can be found in:
apt-file search swrast_dri.so
--> libgl1-mesa-dri: /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so
Then I will install that package
sudo apt install libgl1-mesa-dri
and try again.
If apt-file isn't installed, you can install it by typing
sudo apt install apt-file
apt-file update
That being said, anki is one of the very few packages I'm downloading directly from their website apps.ankiweb.net because it's a very active project. Installation instructions are provided on the same page. If you do this, make sure to remove the packaged version from your system beforehand: sudo apt remove anki
jcsjcs
  • 71
