Main Issue is:
# systemctl status systemd-resolved.service
systemd-resolved.service - Network Name Resolution Loaded: loaded (/lib/systemd/system/systemd-resolved.service; enabled; vendor preset: enabled) Active: failed (Result: resources) since Wed 2021-05-19 11:15:15 UTC; 23s ago Docs: man:systemd-resolved.service(8) https://www.freedesktop.org/wiki/Software/systemd/resolved https://www.freedesktop.org/wiki/Software/systemd/writing-network-configuration-managers https://www.freedesktop.org/wiki/Software/systemd/writing-resolver-clients
May 19 11:15:15 kv-server systemd[1]: systemd-resolved.service: Service has no hold-off time, scheduling restart. May 19 11:15:15 kv-server systemd[1]: systemd-resolved.service: Scheduled restart job, restart counter is at 5. May 19 11:15:15 kv-server systemd[1]: Stopped Network Name Resolution. May 19 11:15:15 kv-server systemd[1]: systemd-resolved.service: Start request repeated too quickly. May 19 11:15:15 kv-server systemd[1]: systemd-resolved.service: Failed with result 'resources'. May 19 11:15:15 kv-server systemd[1]: Failed to start Network Name Resolution.
This issue was something which I landed up by doing the below steps:
apt-get update was failing. I started by following the answer of https://askubuntu.com/a/91590/1042537
This explained the issue and pointed fault towards DNS.
To configure dns servers, I followed https://stackoverflow.com/a/54460886/14950576 .
I also did # chattr +i /etc/resolv.conf so that resolv.conf doesn't get updated by DHCP
I tried # ping google.com but it still failed.
I observed a bad symlink /etc/resolv.conf -> /run/systemd/resolve/stub-resolve.conf So I tried to access /run/systemd/resolve/stub-resolve.conf
Got an error that there is no directory /run/systemd/resolve
So I followed https://unix.stackexchange.com/a/613143 and got to know that systemd-resolved.service was not running.
Error I got was
# systemctl enable --now systemd-resolved.service
Job for systemd-resolved.service failed because of unavailable resources or another system error.
See "systemctl status systemd-resolved.service" and "journalctl -xe" for details.
As I tried to do start that, I ran into the main issue.
So Network Name Resolution is unable to start.
I am a novice contributor. Would like suggetions to improve the answer !!
Although a lot of errors are raised by #systemctl status systemd-resolved.service The main issue was resources.
This issue was caused by the absence of tmp directory in var
i.e. /var/tmp/ was absent.
Solution:
mkdir /var/tmp
chmod 777 /var/tmp
777 permission is a bad practice for webservers as it gives read/write access to every user. So please use it accordingly
Then to start the service, I performed:
Then, ping google.com gives successful result.
Solution was inspired from https://www.raspberrypi.org/forums/viewtopic.php?t=249619
PS: For other errors:
You can view https://serverfault.com/a/1032451
For good resources on systemd-resolved name resolution view:
https://www.youtube.com/watch?v=DtFjrJdnWAU
https://moss.sh/name-resolution-issue-systemd-resolved/
https://unix.stackexchange.com/questions/328131/how-to-troubleshoot-dns-with-systemd-resolved
dopexxx
  • 233
