Trying to upgrade from Ubuntu 20.04 to 20.10 (the updater offered the upgrade), when I click the Upgrade button, nothing happens and the updater exits. Trying from the command line there are no errors either until I noticed that there was a package that needed upgrading but I am unsure how to do it. Below are my attempts and I hope it's not too much information! I'm not sure what else to try so any ideas?
I was finally able to get a meaningful error so I've appended the command line text. Still no solution but an error is a place to start!
    $ sudo apt upgrade
    Reading package lists... Done
    Building dependency tree
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      adobe-flash-properties-gtk libllvm10 libllvm10:i386
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      libxnvctrl0 ubuntu-advantage-tools
    2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 784 kB of archives.
    After this operation, 2,331 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 ubuntu-advantage-tools amd64 27.0.2~20.04.1 [773 kB]
    Get:2 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 libxnvctrl0 amd64 460.39-0ubuntu0.20.04.1 [11.0 kB]
    Fetched 784 kB in 1s (987 kB/s)
    Preconfiguring packages ...
    (Reading database ... 452762 files and directories currently installed.)
    Preparing to unpack .../ubuntu-advantage-tools_27.0.2~20.04.1_amd64.deb ...
    Unpacking ubuntu-advantage-tools (27.0.2~20.04.1) over (20.3) ...
    Preparing to unpack .../libxnvctrl0_460.39-0ubuntu0.20.04.1_amd64.deb ...
    Unpacking libxnvctrl0:amd64 (460.39-0ubuntu0.20.04.1) over (440.64-0ubuntu1) ...
    Setting up libxnvctrl0:amd64 (460.39-0ubuntu0.20.04.1) ...
    Setting up ubuntu-advantage-tools (27.0.2~20.04.1) ...
    Installing new version of config file /etc/apt/apt.conf.d/20apt-esm-hook.conf ..
    Installing new version of config file /etc/ubuntu-advantage/uaclient.conf ...
    Created symlink /etc/systemd/system/multi-user.target.wants/ua-reboot-cmds.servi
    ce → /lib/systemd/system/ua-reboot-cmds.service.
    Created symlink /etc/systemd/system/timers.target.wants/ua-messaging.timer → /li
    b/systemd/system/ua-messaging.timer.
    Processing triggers for man-db (2.9.1-1) ...
    Processing triggers
$ sudo apt upgrade Reading package lists... Done Building dependency tree
Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: adobe-flash-properties-gtk libllvm10 libllvm10:i386 Use 'sudo apt autoremove' to remove them. The following packages will be upgraded: libxnvctrl0 ubuntu-advantage-tools 2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 784 kB of archives. After this operation, 2,331 kB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 ubuntu-advantage-tools amd64 27.0.2~20.04.1 [773 kB] Get:2 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 libxnvctrl0 amd64 460.39-0ubuntu0.20.04.1 [11.0 kB] Fetched 784 kB in 1s (987 kB/s)
Preconfiguring packages ... (Reading database ... 452762 files and directories currently installed.) Preparing to unpack .../ubuntu-advantage-tools_27.0.2~20.04.1_amd64.deb ... Unpacking ubuntu-advantage-tools (27.0.2~20.04.1) over (20.3) ... Preparing to unpack .../libxnvctrl0_460.39-0ubuntu0.20.04.1_amd64.deb ... Unpacking libxnvctrl0:amd64 (460.39-0ubuntu0.20.04.1) over (440.64-0ubuntu1) ... Setting up libxnvctrl0:amd64 (460.39-0ubuntu0.20.04.1) ... Setting up ubuntu-advantage-tools (27.0.2~20.04.1) ... Installing new version of config file /etc/apt/apt.conf.d/20apt-esm-hook.conf .. . Installing new version of config file /etc/ubuntu-advantage/uaclient.conf ... Created symlink /etc/systemd/system/multi-user.target.wants/ua-reboot-cmds.servi ce → /lib/systemd/system/ua-reboot-cmds.service. Created symlink /etc/systemd/system/timers.target.wants/ua-messaging.timer → /li b/systemd/system/ua-messaging.timer. Processing triggers for man-db (2.9.1-1) ... Processing triggers for libc-bin (2.31-0ubuntu9.2) ... libdvd-pkg: Package libdvdcss2-1.4.2-1 was removed, stop processing...
$ sudo apt dist-upgrade Reading package lists... Done Building dependency tree
Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: adobe-flash-properties-gtk libllvm10 libllvm10:i386 Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ sudo apt autoremove Reading package lists... Done Building dependency tree
Reading state information... Done The following packages will be REMOVED: adobe-flash-properties-gtk libllvm10 libllvm10:i386 0 upgraded, 0 newly installed, 3 to remove and 1 not upgraded. After this operation, 143 MB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 452781 files and directories currently installed.) Removing adobe-flash-properties-gtk (1:20201231.1-0ubuntu0.20.04.1) ... Removing libllvm10:amd64 (1:10.0.0-4ubuntu1) ... Removing libllvm10:i386 (1:10.0.0-4ubuntu1) ... Processing triggers for libc-bin (2.31-0ubuntu9.2) ... libdvd-pkg: Package libdvdcss2-1.4.2-1 was removed, stop processing...
Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ sudo do-release-upgrade sudo: do-release--upgrade: command not found
$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.2 LTS Release: 20.04 Codename: focal
$ sudo update-manager Checking for a new Ubuntu release Please install all available updates for your release before upgrading.
$ sudo apt update Hit:1 http://us.archive.ubuntu.com/ubuntu focal InRelease Hit:2 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:3 http://ppa.launchpad.net/otto-kesselgulasch/gimp/ubuntu focal InRelease
Hit:4 http://archive.canonical.com/ubuntu focal InRelease
Reading state information... Done 1 package can be upgraded. Run 'apt list --upgradable' to see it.
$ sudo apt list --upgradable Listing... Done libgegl-0.4-0/focal 1:0.4.18+om-0ubu20.04.18~ppa amd64 [upgradable from: 0.4.22-3] N: There is 1 additional version. Please use the '-a' switch to see it
$ sudo apt list --upgradable -a Listing... Done libgegl-0.4-0/focal 1:0.4.18+om-0ubu20.04.18~ppa amd64 [upgradable from: 0.4.22-3] libgegl-0.4-0/focal,now 0.4.22-3 amd64 [installed,upgradable to: 1:0.4.18+om-0ubu20.04.18~ppa]
$ sudo apt update && sudo apt upgrade -y Hit:1 http://us.archive.ubuntu.com/ubuntu focal InRelease Hit:2 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:4 http://archive.canonical.com/ubuntu focal InRelease Reading package lists... Done Building dependency tree
Reading state information... Done 1 package can be upgraded. Run 'apt list --upgradable' to see it. Reading package lists... Done Building dependency tree
$ sudo apt --only-upgrade install 1:0.4.18+om-0ubu20.04.18~ppa Reading package lists... Done Building dependency tree
Reading state information... Done E: Unable to locate package 1:0.4.18+om-0ubu20.04.18~ppa
$ sudo apt-get --only-upgrade install 1:0.4.18+om-0ubu20.04.18~ppa Reading package lists... Done Building dependency tree
Reading state information... Done E: Unable to locate package 1:0.4.18+om-0ubu20.04.18~ppa E: Couldn't find any package by glob '1:0.4.18+om-0ubu20.04.18~ppa' E: Couldn't find any package by regex '1:0.4.18+om-0ubu20.04.18~ppa'
$ sudo apt full-upgrade Reading package lists... Done Building dependency tree
$ sudo apt-get --with-new-pkgs upgrade Reading package lists... Done Building dependency tree
Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
$ sudo apt-get dist-upgrade Reading package lists... Done Building dependency tree
Reading state information... Done Calculating upgrade... Done for libc-bin (2.31-0ubuntu9.2) ... libdvd-pkg: Package libdvdcss2-1.4.2-1 was removed, stop processing...
$ sudo do-release--upgrade sudo: do-release--upgrade: command not found
There are the errors and it seems that in order to upgrade, something that is noit available needs to be installed:
$ sudo apt-get --only-upgrade install libgegl-0.4-0 Reading package lists... Done Building dependency tree
Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: libgegl-0.4-0 : Depends: libopenexr23 but it is not installable E: Unable to correct problems, you have held broken packages.
$ sudo apt-get install libopenexr23 Reading package lists... Done Building dependency tree
Reading state information... Done Package libopenexr23 is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source However the following packages replace it: libopenexr24:i386 libopenexr24
E: Package 'libopenexr23' has no installation candidate
$ sudo apt-get install libopenexr24:i386 Reading package lists... Done Building dependency tree
Reading state information... Done The following additional packages will be installed: libilmbase24:i386 The following NEW packages will be installed: libilmbase24:i386 libopenexr24:i386 0 upgraded, 2 newly installed, 0 to remove and 1 not upgraded. Need to get 677 kB of archives. After this operation, 3,770 kB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 http://us.archive.ubuntu.com/ubuntu focal/universe i386 libilmbase24 i386 2.3.0-6build1 [75.8 kB] Get:2 http://security.ubuntu.com/ubuntu focal-security/universe i386 libopenexr24 i386 2.3.0-6ubuntu0.5 [601 kB] Fetched 677 kB in 1s (1,003 kB/s)
Selecting previously unselected package libilmbase24:i386. (Reading database ... 452769 files and directories currently installed.) Preparing to unpack .../libilmbase24_2.3.0-6build1_i386.deb ... Unpacking libilmbase24:i386 (2.3.0-6build1) ... Selecting previously unselected package libopenexr24:i386. Preparing to unpack .../libopenexr24_2.3.0-6ubuntu0.5_i386.deb ... Unpacking libopenexr24:i386 (2.3.0-6ubuntu0.5) ... Setting up libilmbase24:i386 (2.3.0-6build1) ... Setting up libopenexr24:i386 (2.3.0-6ubuntu0.5) ... Processing triggers for libc-bin (2.31-0ubuntu9.2) ... libdvd-pkg: Package libdvdcss2-1.4.2-1 was removed, stop processing...
$ sudo apt-get install libopenexr24 Reading package lists... Done Building dependency tree
Reading state information... Done libopenexr24 is already the newest version (2.3.0-6ubuntu0.5). libopenexr24 set to manually installed. 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
$ sudo apt-get --only-upgrade install libopenexr23 Reading package lists... Done Building dependency tree
Additional output based on comment:
$ apt-cache depends 1:0.4.18+om-0ubu20.04.18~ppa
E: No packages found
$ apt show 1:0.4.18+om-0ubu20.04.18~ppa | grep Section:
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
E: No packages found $ sudo apt remove 1:0.4.18+om-0ubu20.04.18~ppa
$ sudo apt purge 1:0.4.18+om-0ubu20.04.18~ppa Reading package lists... Done Building dependency tree
Output based on one answer:
$ sudo apt clean
$ sudo apt update Hit:1 http://archive.canonical.com/ubuntu focal InRelease Hit:2 http://us.archive.ubuntu.com/ubuntu focal InRelease
Get:3 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Hit:4 http://ppa.launchpad.net/otto-kesselgulasch/gimp/ubuntu focal InRelease
Fetched 114 kB in 1s (133 kB/s)
Added output from comment:
$ sudo apt-get -s install --reinstall libgegl-0.4-0=0.4.22-3
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Inst libgegl-0.4-0 [0.4.22-3] (0.4.22-3 Ubuntu:20.04/focal [amd64])
Conf libgegl-0.4-0 (0.4.22-3 Ubuntu:20.04/focal [amd64])
DonP
  • 492
Check if any other packages depends on the 1:0.4.18+om-0ubu20.04.18~ppa that can't be upgraded.
Show the software repository of the 1:0.4.18+om-0ubu20.04.18~ppa package that can't be upgraded. If this repository is a PPA that is no longer needed it can be removed with ppa-purge.
The empty results of apt show 1:0.4.18+om-0ubu20.04.18~ppa show that 1:0.4.18+om-0ubu20.04.18~ppa is not installed. Delete the apt cache from /var/cache/apt .
sudo apt clean
sudo apt update
sudo apt upgrade
karel
  • 122,292
  • 133
  • 301
  • 332
None of the command line tools and functions seemed to work so I finally resorted to the GUI. By going to
Software Updater->Settings->Ubuntu Software and choosing Main Server instead of Server for United States,
then
Software Updater->Settings->Other Software and unchecking everything except Conanical Partners,
the upgrading ran as it should.
DonP
  • 492
