I am getting the following error while trying to build a Dockerfile for the linux/arm64 platform:
#5 58.06 Processing triggers for libc-bin (2.31-11) ...
#5 58.12 qemu: uncaught target signal 11 (Segmentation fault) - core dumped
#5 58.33 Segmentation fault (core dumped)
#5 58.35 qemu: uncaught target signal 11 (Segmentation fault) - core dumped
#5 58.69 Segmentation fault (core dumped)
#5 58.70 dpkg: error processing package libc-bin (--configure):
#5 58.70 installed libc-bin package post-installation script subprocess returned error exit status 139
#5 58.70 Processing triggers for ca-certificates (20210119) ...
#5 58.87 Updating certificates in /etc/ssl/certs...
#5 71.86 0 added, 0 removed; done.
#5 71.86 Running hooks in /etc/ca-certificates/update.d...
#5 71.89 done.
#5 71.98 Errors were encountered while processing:
#5 71.98 libc-bin
#5 72.06 E: Sub-process /usr/bin/dpkg returned an error code (1)
I have trimmed my Dockerfile all the way to the below contents:
FROM kalilinux/kali-rolling
ARG DEBIAN_FRONTEND=noninteractive
ARG TARGETPLATFORM
RUN apt update && \
apt install wget -y
Solution Attempt #1
The first thing that came to mind was this: https://stackoverflow.com/questions/59139453/repository-is-not-signed-in-docker-build/66215465#66215465. I ran across this while just installing things on an ARM 32-bit processor, and so I tried adding the same dependencies into this Dockerfile, with no success. These dependencies were:
- http://ftp.us.debian.org/debian/pool/main/g/glibc/libc-bin_2.31-12_arm64.deb
- http://ftp.us.debian.org/debian/pool/main/libs/libseccomp/libseccomp2_2.5.1-1_arm64.deb
However, the issue still persists.
Solution Attempt #2
I ran across https://github.com/docker/for-linux/issues/1131 and tried appending -o APT::Immediate-Configure=0 to get my apt install command, but that didn't work either.
Solution Attempt #3
Next, I ran across this answer: https://askubuntu.com/a/1035226/269349. When I modified my Dockerfile to look like this:
ARG TARGETPLATFORM
RUN apt update && \
rm /var/cache/ldconfig/aux-cache && \
/sbin/ldconfig && \
apt install wget -y -o APT::Immediate-Configure=0
the next error I started receiving is this:
=> ERROR [2/2] RUN apt update && rm /var/cache/ldconfig/aux-cache && /sbin/ldconfig && apt install wget -y -o APT::Immediate-Configure=0 77.8s
> [2/2] RUN apt update && rm /var/cache/ldconfig/aux-cache && /sbin/ldconfig && apt install wget -y -o APT::Immediate-Configure=0:
#5 0.203
#5 0.204 WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
#5 0.205
#5 1.055 Get:1 http://mirrors.jevincanders.net/kali kali-rolling InRelease [30.5 kB]
#5 3.496 Get:2 http://mirrors.jevincanders.net/kali kali-rolling/non-free arm64 Packages [157 kB]
#5 4.211 Get:3 http://mirrors.jevincanders.net/kali kali-rolling/main arm64 Packages [17.5 MB]
#5 67.37 Get:4 http://mirrors.jevincanders.net/kali kali-rolling/contrib arm64 Packages [87.3 kB]
#5 71.57 Fetched 17.8 MB in 1min 11s (249 kB/s)
#5 71.57 Reading package lists...
#5 76.73 Building dependency tree...
#5 77.44 Reading state information...
#5 77.51 4 packages can be upgraded. Run 'apt list --upgradable' to see them.
#5 77.55 qemu: uncaught target signal 11 (Segmentation fault) - core dumped
#5 77.74 Segmentation fault (core dumped)
Dockerfile:4
3 | ARG TARGETPLATFORM
4 | >>> RUN apt update && \
5 | >>> rm /var/cache/ldconfig/aux-cache && \
6 | >>> /sbin/ldconfig && \
7 | >>> apt install wget -y -o APT::Immediate-Configure=0
8 |
Solution Attempt #4
I tried the answer right below the one from the previous answer (reinstalling libc-bin), but then ran into this issue:
#4 25.05 Get:1 http://mirrors.jevincanders.net/kali kali-rolling/main arm64 libc-bin arm64 2.31-11 [735 kB]
#4 27.93 debconf: delaying package configuration, since apt-utils is not installed
#4 28.12 Fetched 735 kB in 2s (295 kB/s)
(Reading database ... 6748 files and directories currently installed.)
#4 28.30 Preparing to unpack .../libc-bin_2.31-11_arm64.deb ...
#4 28.32 Unpacking libc-bin (2.31-11) over (2.31-11) ...
#4 28.84 Setting up libc-bin (2.31-11) ...
#4 28.98 qemu: uncaught target signal 11 (Segmentation fault) - core dumped
#4 29.20 Segmentation fault (core dumped)
#4 29.22 qemu: uncaught target signal 11 (Segmentation fault) - core dumped
#4 29.42 Segmentation fault (core dumped)
#4 29.42 dpkg: error processing package libc-bin (--configure):
#4 29.42 installed libc-bin package post-installation script subprocess returned error exit status 139
#4 29.43 Errors were encountered while processing:
#4 29.43 libc-bin
#4 29.51 E: Sub-process /usr/bin/dpkg returned an error code (1)
Here's the command that I'm running: docker buildx build --platform linux/arm64 .
Any help would be greatly appreciated.
