What exactly does the following error mean, and how do I resolve it? It came up when I tried to install a package Thank you!
Dependency is not satisfiable: python3 (>= 3.9~)
The package you are trying to install requires Python 3.9 or above.
https://packages.ubuntu.com/search?keywords=python3 says that Ubuntu 21.04 has python version 3.9, whereas Ubuntu 20.04 has Python 3.8 by default. You would need Ubuntu 21.04 to use the package you were trying to install.
You can also install Python 3.9 in supported LTS versions of Ubuntu with the Deadsnakes PPA, but the name of that python package will be python3.9, and the package you were trying to install will probably still refuse to install (because it requires python3 to have a version >= 3.9). In that case, you would have to download the source package, and rebuild it to work with python3.9 (that is a lot of work).
If you let us know about the package you were trying to install, we can try to help you install it.
You should not try to install .deb files built for one version of Ubuntu in another version (see this question). That may break dependency cycles, and you would have to reinstall to fix it.
