I am new to Linux, so this might sound like a simple question, but how do I install a package outside of the APT database? I am trying to install the following package:
https://launchpad.net/ubuntu/+source/pdb2pqr
Any help will be appreciated. Thank you!
Let's assume you are currently running Huriste Hippo (21.04).
  1. Expand "The Hirsute Hippo (current stable release)" section.
    You will see a list of Package files.
  2. Select and download the the *.deb (*.ddeb) files for your architecture.
    For AMD64, you would pick:
  3. Open a terminal and execute the following commands.
    Let's assume you downloaded these files to your Downloads directory.
    cd ~/Downloads
  4. Add the universe repository so Ubuntu can download other dependent packages you may need. Also this is needed for the gdebi command below.
    sudo apt-add-repository universe
    sudo apt update
  5. Install gdebi, a tool to allow you to install *.deb files and automatically install their dependencies.
    sudo apt install gdebi-core
  6. Install your downloaded packages.
    sudo gdebi pdb2pqr_2.1.1+dfsg-7build1_amd64.deb
    sudo gdebi pdb2pqr-doc_2.1.1+dfsg-7build1_all.deb
    sudo gdebi pdb2pqr-dbgsym_2.1.1+dfsg-7build1_amd64.ddeb
Enterprise
  • 12,792
