I'm not very experienced with Ubuntu and when I started playing around with Python a year I assume I overwrote some important dependencies.
I made it even worse by trying to fix the issues and now I can't install or use nodejs which is essential for my work.
When I run sudo apt update I get the following error
Get:34 http://nl.archive.ubuntu.com/ubuntu focal-backports/universe amd64 DEP-11 Metadata [1.768 B]
Fetched 6.700 kB in 5s (1.312 kB/s)
Traceback (most recent call last):
  File "/usr/lib/cnf-update-db", line 8, in <module>
from CommandNotFound.db.creator import DbCreator
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 11, in <module>
import apt_pkg
ModuleNotFoundError: No module named 'apt_pkg'
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
When I run sudo apt --fix-broken install I get the following error
Building dependency tree
Correcting dependencies... failed.
 gir1.2-gtk-3.0 : Depends: gir1.2-gdkpixbuf-2.0 (>= 2.40.0) but 2.36.11-2 is installed
              Depends: gir1.2-pango-1.0 (>= 1.41.0) but 1.40.14-1ubuntu0.1 is installed
              Depends: libgtk-3-0 (>= 3.24.7) but 3.22.30-1ubuntu4 is installed
 python3-cairo : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is installed
 python3-gi : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is installed
          Depends: libgirepository-1.0-1 (>= 1.62.0-4~) but 1.56.1-1 is installed
 python3-gi-cairo : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is installed
 python3-markupsafe : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is installed
 python3-netifaces : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is installed
 python3-protobuf : Depends: libprotobuf17 but it is not installed
 python3-reportlab-accel : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is installed
 python3-sip : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is installed
 python3-zope.interface : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
Before it got to this state I saw that I had around 1600 outdated packages. I realize this isn't an easy issue to fix but any help would be greatly appreciated.
When trying to install aptitude
You might want to run 'apt --fix-broken install' to correct these.
 aptitude : Depends: aptitude-common (= 0.8.12-1ubuntu4) but it is not going to be installed
        Depends: libapt-pkg6.0 (>= 1.9.11~) but it is not going to be installed
        Depends: libboost-iostreams1.71.0 but it is not going to be installed
        Depends: libcwidget4 (>= 0.5.18-1) but it is not going to be installed
        Depends: libncursesw6 (>= 6.1+20180210) but it is not going to be installed
        Depends: libxapian30 (>= 1.4.14~) but 1.4.5-1ubuntu0.1 is to be installed
 gir1.2-gtk-3.0 : Depends: gir1.2-gdkpixbuf-2.0 (>= 2.40.0) but 2.36.11-2 is to be installed
              Depends: gir1.2-pango-1.0 (>= 1.41.0) but 1.40.14-1ubuntu0.1 is to be installed
              Depends: libgtk-3-0 (>= 3.24.7) but 3.22.30-1ubuntu4 is to be installed
 python3-cairo : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is to be installed
 python3-gi : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is to be installed
          Depends: libgirepository-1.0-1 (>= 1.62.0-4~) but 1.56.1-1 is to be installed
 python3-gi-cairo : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is to be installed
 python3-markupsafe : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is to be installed
 python3-netifaces : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is to be installed
 python3-protobuf : Depends: libprotobuf17 but it is not going to be installed
 python3-reportlab-accel : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is to be installed
 python3-sip : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is to be installed
 python3-zope.interface : Depends: python3 (>= 3.8~) but 3.6.7-1~18.04 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Gezzasa
  • 101
You have a line that says ModuleNotFoundError: No module named 'apt_pkg'. You can try using solutions in this question.
Another approach to handle unmet dependencies is to use aptitude. aptitude can make suggestions to fix the underlying problem.
sudo apt install aptitude
sudo aptitude update
