I'm running Ubuntu 21.04 and Gnome40.
Two days ago I read (on reddit) about gnome 40 and how to install it on Ubuntu. Since I have some issues with the stock desktop environment, I thought "why not give it a try". So I installed it and everything works fine.
While searching how to get the application-menu on the left hand side of the screen back, like it is in the stock environment, I came across plank (and the dash to plank gnome extension) which caught my eye. So I installed both and again it worked fine and looked awesome.
Today, however an update notifcation popped up and I updated and restarted my system. After that I noticed, that my docker / plank bar was gone. So I looked around and searchend and via terminal I found out, that plank wouldn't start because of following error:
plank: error while loading shared libraries: libwnck-3.so.0: cannot open shared object file: No such file or directory
After unsuccessfully searching the internet for some hours and trying different "solutions" like removing and installing again, forcing a reinstall, trying to install libwnck-3-0 and so on, I finally completely removed ubuntu from my pc, wiped both disks and did a fresh install. (Was overdue anyway).
But even with this fresh install, plank won't start due to the same error.
So if someone knows a solution to this problem I would highly appreciate it. :)
If you have further questions, please feel free to ask.
Thanks in advance.
Output of apt-cache policy gnome-shell plank libwnck-3-0:
gnome-shell:
Installiert: 40.1-0shemgpubuntu2
Installationskandidat: 40.1-0shemgpubuntu2
Versionstabelle:
*** 40.1-0shemgpubuntu2 500
500 http://ppa.launchpad.net/shemgp/gnome-40/ubuntu hirsute/main amd64 Packages
100 /var/lib/dpkg/status
3.38.4-1ubuntu2 500
500 http://de.archive.ubuntu.com/ubuntu hirsute/main amd64 Packages
plank:
Installiert: 0.11.89-3
Installationskandidat: 0.11.89-3
Versionstabelle:
*** 0.11.89-3 500
500 http://de.archive.ubuntu.com/ubuntu hirsute/universe amd64 Packages
libwnck-3-0:
Installiert: 1:40.0-1shemgpubuntu5
Installationskandidat: 1:40.0-1shemgpubuntu5
Versionstabelle:
*** 1:40.0-1shemgpubuntu5 500
3.36.0-1 500
