This is basically a followup to CPU frquency scaling broken on upgrade from Ubuntu 20.04->20.10 (Intel CPU)
However, I'm not allowed to comment, and it was suggested to write a new question instead. Please read the original question for additional information from the other poster.
I'm experiencing the exact same issue after upgrading from kubuntu 20.10 to kubuntu 21.04: a completely different cpu frequency scaling behavior with the the CPU frequency often getting stuck at 400 MHz.
With kubuntu 20.10 my newly bought AsusVivoBook S14 S435 with i7-1165G7 was blazing fast. Upon demand frequencies would scale up to >4 GHz, then slowly stabilize at >2.8 GHz when using all 4 cores (=8 CPUs) at 100%, while the fan speed increases considerably. CPU core and "Composite" temperatures are around 90°C.
With kubuntu 21.04 only scales up to around 4 GHz for a very little time, then drops down to around 1 GHz and often even to 400 MHz while temperatures remain <60°C and the CPU fan remains at low RPMs. Sometimes the throttling goes on for a few seconds, sometimes it seems completely stuck at 400 MHz for minutes and longer (I usually just reboot when it gets stuck).
In both cases intel_pstate seems active with two governors to choose from (powersafe and performance), but when the frequency is stuck at low values it doesn't matter which one is active or what frequency I manually set.
I thought it must be a difference in kernel: 5.8 on kubuntu 20.10 and 5.11 on kubuntu 21.04. However, that's not the case: I've tried kernels 5.8 / 5.10 / 5.11 and 5.12 with kubuntu 21.04 and the behavior doesn't change.
I've temporarily fixed the fan to maximum RPMs to see if it changes anything. Temperatures were even lower, but throttling to 400 MHz continued.
I've also excluded that it might be a glitch in the BIOS: just about the time when I've upgraded to 21.04, I've also upgraded the BIOS from 3.01 to 3.02. Even after downgrading to 3.01 the behavior remained the same.
Finally I've started kubuntu 20.10 from an external hard drive to exclude any actual hardware issues -- and my computer was blazing fast again.
I've now re-installed kubuntu 20.10 and am happy. But at some point I'll have to upgrade since support for 20.10 will run out in a couple of months. But without knowing what is causing the throttling of the CPU that's not really an option.
Does anyone have any idea what can cause the throttling even though all relevant temperatures are low?
-------------------- EDIT ------------------
Doug Smythies requested to post turbostat information when the throttling occurs.
I have taken three sets of readings:
- With 20.10
- With 21.04 before throttling has occurred
- With 21.04 while throttling to 400 MHz was active
Differences between 1+2 (20.10 --> 21.04)
cpu0: MSR_PKG_POWER_LIMIT: 0x4381e0001f81e0 (UNlocked)
cpu0: PKG Limit #1: ENabled (60.000000 Watts, 32.000000 sec, clamp ENabled)
cpu0: PKG Limit #2: ENabled (60.000000 Watts, 0.002441* sec, clamp ENabled)
Core CPU Avg_MHz Busy% Bzy_MHz TSC_MHz IRQ SMI POLL C1_ACPI C2_ACPI C3_ACPI POLL% C1_ACPI% C2_ACPI% C3_ACPI% CPU%c1 CPU%c6 CPU%c7 CoreTmp PkgTmp GFX%rc6 GFXMHz Totl%C0 Any%C0 GFX%C0 CPUGFX% Pkg%pc2 Pkg%pc3 Pkg%pc6 Pkg%pc7 Pkg%pc8 Pkg%pc9 Pk%pc10 CPU%LPI SYS%LPI PkgWatt CorWatt GFXWatt RAMWatt PKG_% RAM_%
- - 235 12.63 1857 2803 13152 0 6 18360 13073 6431 0.00 21.96 37.80 27.82 45.14 0.00 42.23 44 46 58.47 400 93.76 53.92 41.08 20.86 3.44 4.42 0.00 0.00 0.00 0.00 0.00 0.00 0.00 8.84 3.39 0.58 0.00 0.00 0.00
cpu0: MSR_PKG_POWER_LIMIT: 0x4381e0001f80e0 (UNlocked)
cpu0: PKG Limit #1: ENabled (28.000000 Watts, 32.000000 sec, clamp ENabled)
Core CPU Avg_MHz Busy% Bzy_MHz TSC_MHz IRQ SMI POLL C1ACPI C2ACPI C3ACPI POLL% C1ACPI% C2ACPI% C3ACPI% CPU%c1 CPU%c6 CPU%c7 CoreTmp PkgTmp GFX%rc6 GFXMHz GFXAMHz Totl%C0 Any%C0 GFX%C0 CPUGFX% Pkg%pc2 Pkg%pc3 Pkg%pc6 Pkg%pc7 Pkg%pc8 Pkg%pc9 Pk%pc10 CPU%LPI SYS%LPI PkgWatt CorWatt GFXWatt RAMWatt PKG_% RAM_%
- - 12 0.91 1300 2803 1195 0 0 209 507 1134 0.00 0.64 4.86 93.60 2.50 0.00 96.59 28 30 99.28 450 100 7.70 5.55 0.68 0.38 90.22 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 4.00 0.26 0.14 0.00 0.00 0.00
Differences between 2+3 (21.04 (normal) --> 21.04 (throttled to 400 MHz))
cpu0: MSR_PKG_POWER_LIMIT: 0x4381e000dd802f (UNlocked)
cpu0: PKG Limit #1: ENabled (5.875000 Watts, 28.000000 sec, clamp ENabled)
- - 399 99.77 400 2805 17154 0 0 0 0 0 0.00 0.00 0.00 0.00 0.23 0.00 0.00 38 40 86.78 100 100 400.80 100.20 13.29 13.29 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 5.73 1.71 0.11 0.00 100.16 0.00
I've also printed read out all the settings in /var/sys/devices/cpu/ and compared them. From /sys/devices/system/cpu/cpu7/thermal_throttle/package_throttle_total_time_ms = 104652 it's confirmed that some kind of thermal throttling is going on that's different under 20.10.
- turbostat_2010.txt
turbostat version 20.03.20 - Len Brown <lenb@kernel.org>
CPUID(0): GenuineIntel 0x1b CPUID levels; 0x80000008 xlevels; family:model:stepping 0x6:8c:1 (6:140:1)
CPUID(1): SSE3 MONITOR - EIST TM2 TSC MSR ACPI-TM HT TM
CPUID(6): APERF, TURBO, DTS, PTM, HWP, HWPnotify, HWPwindow, HWPepp, HWPpkg, EPB
cpu0: MSR_IA32_MISC_ENABLE: 0x00850089 (TCC EIST MWAIT PREFETCH TURBO)
CPUID(7): No-SGX
CPUID(0x15): eax_crystal: 2 ebx_tsc: 146 ecx_crystal_hz: 38400000
TSC: 2803 MHz (38400000 Hz * 146 / 2 / 1000000)
CPUID(0x16): base_mhz: 2800 max_mhz: 4700 bus_mhz: 100
cpu0: MSR_MISC_PWR_MGMT: 0x00401cc0 (ENable-EIST_Coordination DISable-EPB DISable-OOB)
RAPL: 9362 sec. Joule Counter Range, at 28 Watts
cpu0: MSR_PLATFORM_INFO: 0x4043df0811c00
4 * 100.0 = 400.0 MHz max efficiency frequency
28 * 100.0 = 2800.0 MHz base frequency
cpu0: MSR_IA32_POWER_CTL: 0x0024005b (C1E auto-promotion: ENabled)
cpu0: MSR_TURBO_RATIO_LIMIT: 0x2929292929292f2f
41 * 100.0 = 4100.0 MHz max turbo 8 active cores
41 * 100.0 = 4100.0 MHz max turbo 7 active cores
41 * 100.0 = 4100.0 MHz max turbo 6 active cores
41 * 100.0 = 4100.0 MHz max turbo 5 active cores
41 * 100.0 = 4100.0 MHz max turbo 4 active cores
41 * 100.0 = 4100.0 MHz max turbo 3 active cores
47 * 100.0 = 4700.0 MHz max turbo 2 active cores
47 * 100.0 = 4700.0 MHz max turbo 1 active cores
cpu0: MSR_CONFIG_TDP_NOMINAL: 0x0000001c (base_ratio=28)
cpu0: MSR_CONFIG_TDP_LEVEL_1: 0x000c0060 (PKG_MIN_PWR_LVL1=0 PKG_MAX_PWR_LVL1=0 LVL1_RATIO=12 PKG_TDP_LVL1=96)
cpu0: MSR_CONFIG_TDP_LEVEL_2: 0x00110078 (PKG_MIN_PWR_LVL2=0 PKG_MAX_PWR_LVL2=0 LVL2_RATIO=17 PKG_TDP_LVL2=120)
cpu0: MSR_CONFIG_TDP_CONTROL: 0x00000000 ( lock=0)
cpu0: MSR_TURBO_ACTIVATION_RATIO: 0x0000001b (MAX_NON_TURBO_RATIO=27 lock=0)
cpu0: MSR_PKG_CST_CONFIG_CONTROL: 0x74008008 (UNdemote-C1, demote-C1, locked, pkg-cstate-limit=8 (unlimited))
current_driver: intel_idle
current_governor: menu
current_governor_ro: menu
cpu0: POLL: CPUIDLE CORE POLL IDLE
cpu0: C1_ACPI: ACPI FFH MWAIT 0x0
cpu0: C2_ACPI: ACPI FFH MWAIT 0x31
cpu0: C3_ACPI: ACPI FFH MWAIT 0x60
cpu0: cpufreq driver: intel_pstate
cpu0: cpufreq governor: powersave
cpufreq intel_pstate no_turbo: 0
cpu0: MSR_MISC_FEATURE_CONTROL: 0x00000000 (L2-Prefetch L2-Prefetch-pair L1-Prefetch L1-IP-Prefetch)
cpu0: MSR_PM_ENABLE: 0x00000001 (HWP)
cpu0: MSR_HWP_CAPABILITIES: 0x010d1c2f (high 47 guar 28 eff 13 low 1)
cpu0: MSR_HWP_REQUEST: 0x80002f04 (min 4 max 47 des 0 epp 0x80 window 0x0 pkg 0x0)
cpu0: MSR_HWP_REQUEST_PKG: 0x8000ff01 (min 1 max 255 des 0 epp 0x80 window 0x0)
cpu0: MSR_HWP_INTERRUPT: 0x00000000 (Dis_Guaranteed_Perf_Change, Dis_Excursion_Min)
cpu0: MSR_HWP_STATUS: 0x00000004 (No-Guaranteed_Perf_Change, No-Excursion_Min)
cpu0: MSR_IA32_ENERGY_PERF_BIAS: 0x00000006 (balanced)
cpu0: MSR_RAPL_POWER_UNIT: 0x000a0e03 (0.125000 Watts, 0.000061 Joules, 0.000977 sec.)
cpu0: MSR_PKG_POWER_INFO: 0x000000e0 (28 W TDP, RAPL 0 - 0 W, 0.000000 sec.)
cpu0: MSR_DRAM_POWER_LIMIT: 0x00000000 (UNlocked)
cpu0: DRAM Limit: DISabled (0.000000 Watts, 0.000977 sec, clamp DISabled)
cpu0: MSR_PP0_POLICY: 0
cpu0: MSR_PP0_POWER_LIMIT: 0x00000000 (UNlocked)
cpu0: Cores Limit: DISabled (0.000000 Watts, 0.000977 sec, clamp DISabled)
cpu0: MSR_PP1_POLICY: 0
cpu0: MSR_PP1_POWER_LIMIT: 0x00000000 (UNlocked)
cpu0: GFX Limit: DISabled (0.000000 Watts, 0.000977 sec, clamp DISabled)
cpu0: MSR_IA32_TEMPERATURE_TARGET: 0x08640000 (100 C)
cpu0: MSR_IA32_PACKAGE_THERM_STATUS: 0x88340808 (48 C)
cpu0: MSR_IA32_PACKAGE_THERM_INTERRUPT: 0x00000003 (100 C, 100 C)
cpu0: MSR_PKGC3_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu0: MSR_PKGC6_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu0: MSR_PKGC7_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu0: MSR_PKGC8_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu0: MSR_PKGC9_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu0: MSR_PKGC10_IRTL: 0x00000000 (NOTvalid, 0 ns)
0 0 217 11.49 1887 2803 1262 0 0 2159 1573 807 0.00 20.51 38.33 29.90 45.59 0.00 42.93 44 46 58.48 400 93.76 53.92 41.09 20.86 3.44 4.42 0.00 0.00 0.00 0.00 0.00 0.00 0.00 8.84 3.40 0.58 0.00 0.00 0.00
0 4 238 13.10 1813 2803 1417 0 1 2387 1846 436 0.00 24.20 46.22 16.69 43.97
1 1 237 12.87 1845 2803 1096 0 1 2019 1520 855 0.00 19.06 34.97 33.32 43.20 0.00 43.93 44
1 5 225 12.33 1825 2803 1525 0 1 2373 1658 946 0.00 21.47 37.60 28.83 43.74
2 2 220 12.15 1813 2803 1405 0 0 2009 1578 1118 0.00 18.78 32.37 36.94 52.68 0.00 35.17 44
2 6 262 14.40 1820 2803 4007 0 1 3733 1861 410 0.00 34.54 42.29 9.03 50.44
3 3 234 12.27 1907 2803 1112 0 1 1943 1435 780 0.00 21.01 35.18 31.75 40.83 0.00 46.90 44
3 7 244 12.44 1959 2803 1328 0 1 1737 1602 1079 0.00 16.17 35.47 36.14 40.67
- turbostat_2104_normal.txt
turbostat version 20.09.30 - Len Brown <lenb@kernel.org>
cpu1: MSR_IA32_MISC_ENABLE: 0x00850089 (TCC EIST MWAIT PREFETCH TURBO)
CPUID(7): No-SGX
cpu1: MSR_MISC_PWR_MGMT: 0x00401cc0 (ENable-EIST_Coordination DISable-EPB DISable-OOB)
cpu1: MSR_PLATFORM_INFO: 0x4043df0811c00
cpu1: MSR_IA32_POWER_CTL: 0x0024005b (C1E auto-promotion: ENabled)
cpu1: MSR_TURBO_RATIO_LIMIT: 0x2929292929292f2f
cpu1: MSR_CONFIG_TDP_NOMINAL: 0x0000001c (base_ratio=28)
cpu1: MSR_CONFIG_TDP_LEVEL_1: 0x000c0060 (PKG_MIN_PWR_LVL1=0 PKG_MAX_PWR_LVL1=0 LVL1_RATIO=12 PKG_TDP_LVL1=96)
cpu1: MSR_CONFIG_TDP_LEVEL_2: 0x00110078 (PKG_MIN_PWR_LVL2=0 PKG_MAX_PWR_LVL2=0 LVL2_RATIO=17 PKG_TDP_LVL2=120)
cpu1: MSR_CONFIG_TDP_CONTROL: 0x00000000 ( lock=0)
cpu1: MSR_TURBO_ACTIVATION_RATIO: 0x0000001b (MAX_NON_TURBO_RATIO=27 lock=0)
cpu1: MSR_PKG_CST_CONFIG_CONTROL: 0x74008008 (UNdemote-C1, demote-C1, locked, pkg-cstate-limit=8 (unlimited))
/dev/cpu_dma_latency: 2000000000 usec (default)
cpu1: POLL: CPUIDLE CORE POLL IDLE
cpu1: C1ACPI: ACPI FFH MWAIT 0x0
cpu1: C2ACPI: ACPI FFH MWAIT 0x31
cpu1: C3ACPI: ACPI FFH MWAIT 0x60
cpu1: cpufreq driver: intel_pstate
cpu1: cpufreq governor: powersave
cpu1: MSR_MISC_FEATURE_CONTROL: 0x00000000 (L2-Prefetch L2-Prefetch-pair L1-Prefetch L1-IP-Prefetch)
cpu0: EPB: 6 (balanced)
cpu1: MSR_IA32_TEMPERATURE_TARGET: 0x08640000 (92 C) (100 default - 8 offset)
cpu0: MSR_IA32_PACKAGE_THERM_STATUS: 0x883e0800 (30 C)
cpu0: MSR_IA32_PACKAGE_THERM_INTERRUPT: 0x00000003 (92 C, 92 C)
cpu1: MSR_PKGC3_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu1: MSR_PKGC6_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu1: MSR_PKGC7_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu1: MSR_PKGC8_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu1: MSR_PKGC9_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu1: MSR_PKGC10_IRTL: 0x00000000 (NOTvalid, 0 ns)
0 0 12 0.92 1260 2803 117 0 0 27 74 175 0.00 0.41 5.34 93.35 2.70 0.00 96.38 27 30 99.28 450 100 7.70 5.55 0.68 0.38 90.22 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 4.00 0.26 0.14 0.00 0.00 0.00
0 4 16 1.29 1245 2803 125 0 0 26 73 148 0.00 0.84 5.18 92.71 2.32
1 1 10 0.86 1210 2803 127 0 0 41 56 92 0.00 1.46 5.82 91.88 3.71 0.00 95.44 26
1 5 12 0.97 1233 2803 267 0 0 40 62 259 0.00 0.78 3.69 94.59 3.59
2 2 4 0.29 1270 2803 59 0 0 25 55 104 0.00 0.48 3.40 95.84 2.07 0.00 97.64 27
2 6 10 0.84 1242 2803 307 0 0 21 100 134 0.00 0.33 7.95 90.89 1.52
3 3 23 1.55 1511 2803 93 0 0 13 32 112 0.00 0.58 2.65 95.22 1.55 0.00 96.90 28
3 7 7 0.55 1270 2803 100 0 0 16 55 110 0.00 0.23 4.88 94.34 2.55
- turbostat_2104_400.txt
CPUID(7): No-SGX
cpu0: C1ACPI: ACPI FFH MWAIT 0x0
cpu0: C2ACPI: ACPI FFH MWAIT 0x31
cpu0: C3ACPI: ACPI FFH MWAIT 0x60
cpu0: MSR_HWP_CAPABILITIES: 0x010f1c2f (high 47 guar 28 eff 15 low 1)
cpu0: MSR_IA32_TEMPERATURE_TARGET: 0x08640000 (92 C) (100 default - 8 offset)
cpu0: MSR_IA32_PACKAGE_THERM_STATUS: 0x88350c00 (39 C)
0 0 399 99.77 400 2804 1556 0 0 0 0 0 0.00 0.00 0.00 0.00 0.23 0.00 0.00 38 40 86.66 100 100 400.44 100.11 13.27 13.27 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 5.72 1.71 0.11 0.00 100.03 0.00
0 4 399 99.77 400 2804 1741 0 0 0 0 0 0.00 0.00 0.00 0.00 0.23
1 1 399 99.77 400 2804 1434 0 0 0 0 0 0.00 0.00 0.00 0.00 0.23 0.00 0.00 38
1 5 399 99.77 400 2804 2433 0 0 0 0 0 0.00 0.00 0.00 0.00 0.23
2 2 399 99.77 400 2804 1551 0 0 0 0 0 0.00 0.00 0.00 0.00 0.23 0.00 0.00 38
2 6 399 99.77 400 2804 2418 0 0 0 0 0 0.00 0.00 0.00 0.00 0.23
3 3 399 99.77 400 2804 2251 0 0 0 0 0 0.00 0.00 0.00 0.00 0.23 0.00 0.00 36
3 7 399 99.77 400 2804 3770 0 0 0 0 0 0.00 0.00 0.00 0.00 0.23
thermald entries in syslog on 20.10 (there's more -- I'm only posting where there are differences between 20.10 and 21.04)
May 16 18:21:19 hatarakibachi-i711 thermald[740]: Possibly some sensors in the PSVT are missing
May 16 18:21:19 hatarakibachi-i711 thermald[740]: Restart in non adaptive mode via systemd
May 16 18:21:19 hatarakibachi-i711 systemd[1]: thermald.service: Succeeded.
May 16 18:47:31 hatarakibachi-i711 kernel: [ 1580.856020] thermal thermal_zone5: failed to read out thermal zone (-61)
thermald entries in syslog on 21.04
May 16 17:57:42 jcs-external thermald[703]: Possibly some sensors in the PSVT are missing
May 16 17:57:42 jcs-external thermald[703]: Restart in non adaptive mode via systemd
May 16 17:57:42 jcs-external systemd[1]: thermald.service: Main process exited, code=exited, status=1/FAILURE
May 16 17:57:42 jcs-external systemd[1]: thermald.service: Failed with result 'exit-code'.
May 16 17:57:42 jcs-external systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 16 17:57:42 jcs-external thermald[888]: 27 CPUID levels; family:model:stepping 0x6:8c:1 (6:140:1)
May 16 17:57:42 jcs-external thermald[888]: Polling mode is enabled: 4
May 16 17:57:42 jcs-external thermald[888]: sensor id 9 : No temp sysfs for reading raw temp
May 16 17:57:42 jcs-external thermald[888]: message repeated 2 times: [ sensor id 9 : No temp sysfs for reading raw temp]
May 16 17:57:42 jcs-external thermald[888]: Config file /etc/thermald/thermal-conf.xml does not exist
May 16 17:57:42 jcs-external thermald[888]: message repeated 2 times: [ Config file /etc/thermald/thermal-conf.xml does not exist]
/etc/thermald/thermal-conf.xml is missing on both installations. When I start thermald by hand, on 20.10 it will complain about the missing configuration file.
ps aux |grep thermald gives no results on 20.10 (haven't tested 21.04 yet).
