I would want "program.deb" to be pre-installed to a Ubuntu Live CD.
The comments above link to lots of options. If you choose to use Cubic, here are some detailed steps:
  1. Install the software:
    sudo apt-add-repository ppa:cubic-wizard/release
    sudo apt update
    sudo apt install --no-install-recommends cubic
  2. Create a new project:
    Launch Cubic.
    On the first page, select a new empty directory. (For example, /home/tank/my_live_cd).
    Click Next
    On the Project page, select your original ISO. (For example ubuntu-21.04-desktop-amd64.iso).
    Default values will be automatically filled out, so just click Next.
    Project page with default values
  3. When you get to the Terminal page, copy your deb file:
    mkdir Temp
    cd Temp
    Drag program.deb onto Cubic's Terminal area to copy it into your new Temp directory.
  4. Then, install your package from your program.deb file:
    apt-add-repository universe
    apt-add-repository multiverse
    apt install --no-install-recommends gdebi-core
    gdebi program.deb
    Install *.deb file
    Remove unnecessary files.
    apt autoremove --purge gdebi-core
    cd ~
    rm -rf Temp
  5. Click through the next pages, accepting the defaults:
    On the Terminal page, click Next.
    On the Packages page, click Next.
    On the Options page, click Next.
    On the Compression page, click Generate.
    On the Generate page, click Finish.
    Click the Close button to exit the application.
Finally, Create a bootable USB, CD, or DVD using your new Live ISO file.
Enterprise
  • 12,792
