Running Ubuntu 20.04. I want to setup a wifi hot-spot which distributes IPs by dhcp. Furthermore I want to connect to this 'hot-spot' by wired ethernet connection. So the wired connection shall be in the same subnet as the wifi hot-spot and shall also distribute IPs by dhcp. I found some tutorials how to setup a hot-spot. I also read that the connection between wifi and wire can be setup by a bridge. But I have no idea how to merge these two approaches. Any hints ?
Maik
  • 111
