I have been using Ubuntu for over 1 year but now I want to change it with Windows 10. I created a bootable USB but when I went into the boot menu my USB didn't show even though legacy boot is enabled and safe boot is turned off.
Reinstalling Windows 10 from Ubuntu
Windows can be installed to boot in BIOS, (Legacy), mode or in UEFI mode. I will describe each method.
BIOS, (Legacy), mode, MSDOS Partition Table
Boot Ubuntu in Legacy mode.
Using GParted, create a 8GB NTFS partition for the installer and a 50GB or larger partition for Windows.
Mount the Windows ISO using
sudo mount -t udf /{Path to ISO}/Win.iso /media/iso, Copy the contents of/media/iso/to the 8GB partition.In Terminal run
sudo update-grubto add the Windows installer to Ubuntu's GRUB menu.Edit the grub.cfg Windows menuentry, to add
ntldr /bootmgron the line afterchainloader +1Reboot and select Windows Recovery Environment from the Boot menu.
Proceed with Windows 10 installation as normal.
UEFI mode, GPT Partition Table
Boot Ubuntu in UEFI mode.
Using GParted, create a 8GB NTFS partition for the installer and a 50GB or larger NTFS partition for Windows.
sudo mount -t udf /{Path to ISO}/Win.iso /media/iso, Copy the contents of/media/iso/to the 8GB partition.It should not be necessary to Update GRUB to boot in UEFI mode. (Please let me know if you find otherwise).
Reboot, The Windows installer should start. At this point you can close the installer to open the GRUB menu.
UEFI Notes:
UEFI properties may vary among vendors.
It may be necessary to add Windows Recovery Environment menuentry by hand.
Some instructions for installing Windows recommend the ISO be extracted to a FAT32 partition. If there are problems using the ISO extracted to NTFS see: https://www.dedoimedo.com/computers/windows-10-usb-media-linux.html, (thanks to oldfred).
I was not able to install as UEFI mode from Legacy Ubuntu on GPT disk.
- 20,530
- 12
- 78
- 125
