After trying to install libclang-dev with sudo apt-get install -y libclang-dev i receive this error:
libclang-dev : Depends: libclang-10-dev (>= 10~) but it is not going to be installed
When I try the solution:
$ wget https://apt.llvm.org/llvm.sh
$ chmod +x llvm.sh
$ sudo ./llvm.sh 12
Thiss occurs:
clang-12 : Depends: libclang-common-12-dev (= 1:12.0.1~++20210511012537+24535af52ae1-1~exp1~20210510233243.87) but it is not going to be installed
clangd-12 : Depends: libclang-common-12-dev (= 1:12.0.1~++20210511012537+24535af52ae1-1~exp1~20210510233243.87) but it is not going to be installed
The output of sudo apt-cache policy libc6
libc6:
Installed: 2.31-0ubuntu9.2
Candidate: 2.31-0ubuntu9.2
Version table:
*** 2.31-0ubuntu9.2 500
500 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages
100 /var/lib/dpkg/status
2.31-0ubuntu9 500
500 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages
