I tried disabling the network manager service with no luck. It takes over a minute a half to boot. Here is the output from
systemd-analyze critical-chain
graphical.target @1min 35.521s
└─multi-user.target @1min 35.521s
  └─plymouth-quit-wait.service @1min 31.228s +4.292s
    └─systemd-user-sessions.service @1min 31.219s +4ms
      └─network.target @1min 31.217s
        └─wpa_supplicant.service @1min 31.689s +10ms
          └─dbus.service @1min 30.455s
            └─basic.target @1min 30.442s
              └─sockets.target @1min 30.442s
                └─uuidd.socket @1min 30.442s
                  └─sysinit.target @1min 30.370s
                    └─systemd-backlight@leds:tpacpi::kbd_backlight.service @952>
                      └─system-systemd\x2dbacklight.slice @538ms
                        └─system.slice @175ms
                          └─-.slice @175ms
lines 1-18/18 (END)
systemd-analyze
Startup finished in 5.415s (kernel) + 1min 35.528s (userspace) = 1min 40.943s
graphical.target reached after 1min 35.521s in userspace
systemd-analyze blame
4.292s plymouth-quit-wait.service
 937ms systemd-logind.service
 846ms accounts-daemon.service
 826ms networkd-dispatcher.service
 798ms udisks2.service
 765ms bluetooth.service
 765ms avahi-daemon.service
 760ms NetworkManager.service
 755ms system76-power.service
 752ms polkit.service
 743ms switcheroo-control.service
 739ms thermald.service
 649ms gpu-manager.service
 647ms dev-mapper-data\x2droot.device
 639ms apport.service
 634ms grub-common.service
 624ms rsyslog.service
 620ms lm-sensors.service
 606ms e2scrub_reap.service
 557ms vpnagentd.service
 504ms fwupd.service
 213ms apparmor.service
 203ms systemd-rfkill.service
lines 1-23
System specifications
  • Distro: Ubuntu
  • Disk encryption: enabled
  • Hardware: Thinkpad X1 Extreme, 8th gen i7 CPU, 32GB RAM, NVIDIA 1050 Ti
  • xanmod kernel version: stable version 5.10.35
It used to boot fast even with disk encryption enabled in the default kernel that came with the Pop os, after installing xanmod kernel I'm facing this slow boot issue. I tried booting from the default kernel and then even removed it but no help.
Zanna
  • 72,312
Naren
It turns out the problem is with the swap partition having different UUID in the configuration files. The system had it waiting for full 90 seconds before entering the login screen is because it was searching for a swap partition that didn't exist.
So a fix to this problem is to boot the system into the recovery mode and check to see if it is searching for a swap partition, if it does the configuration files need to be updated with the proper UUID of the swap partition that does actually exist. If you wish not to have a swap partition then feel free to remove/comment outlines that will be looking for a swap from those files.
This post helps you in finding where those configuration files are and what/how you need to edit them: What to do about “the disk drive for /dev/mapper/cryptswap1 is not ready yet or not present”?
Naren
