I'm unable to launch some snap packages after my system crashed a couple hours ago. Everything was perfectly fine before my system crashed. Started happening when I managed to get my system working again.
Discord for example gives me this error:
ERROR: not connected to the gnome-3-28-1804 content interface.
The docker daemon also won't start:
$ snap logs docker
2021-05-10T09:34:02Z systemd[1]: Stopped Service for snap application docker.dockerd.
2021-05-10T09:34:02Z systemd[1]: Started Service for snap application docker.dockerd.
2021-05-10T09:34:02Z docker.dockerd[9114]: failed to load listeners: can't create unix socket /var/run/docker.sock: listen unix /var/run/docker.sock: bind: operation not permitted
2021-05-10T09:34:02Z systemd[1]: snap.docker.dockerd.service: Main process exited, code=exited, status=1/FAILURE
2021-05-10T09:34:02Z systemd[1]: snap.docker.dockerd.service: Failed with result 'exit-code'.
2021-05-10T09:34:03Z systemd[1]: snap.docker.dockerd.service: Scheduled restart job, restart counter is at 5.
2021-05-10T09:34:03Z systemd[1]: Stopped Service for snap application docker.dockerd.
2021-05-10T09:34:03Z systemd[1]: snap.docker.dockerd.service: Start request repeated too quickly.
2021-05-10T09:34:03Z systemd[1]: snap.docker.dockerd.service: Failed with result 'exit-code'.
2021-05-10T09:34:03Z systemd[1]: Failed to start Service for snap application docker.dockerd.
Brave browser also didn't start, at first I thought I just need to re-install, which worked, BUT without saving my brave data, so the browser now doesn't know any of my pages, bookmarks, settings or anything. (I did NOT use --purge when removing). See: Snapcraft removed all my data without --purge for that issue
EDIT: The issue with brave data have been resolved, it did save that data, just didn't auto-restore the data when I reinstalled. (See the link above for details).
Some information:
~ » snap version 64 ↵ andre@andre-office
snap 2.49.2
snapd 2.49.2
series 16
ubuntu 20.04
kernel 5.4.0-72-generic
