After upgrading to Ubuntu 20.04 from 18.04 I got a drastic (*) increase in heat generation. That much that the fans run non-stop when, for example, writing here.
I've seen some suggestions for solutions in:
but they are generally too complicated for me.
So I am wondering which alternative I have to going back to Ubuntu 18.04? Is it possible that one of the other Ubuntu flavors has better heat management?
(*) EDIT: the temperature increase is about 10 degree C. Thus it's not necessarily drastic, however, in my particular case, it was the difference between quiet + moderately warm (45-65 C - Ubuntu 18.04) and noisy + noticeably warm/hot (55-75 C - Ubuntu 20.04) during office work and a bit video media via the browser.
EDIT: some more info regarding the system
$ lspci -nnk | grep VGA -A1
00:02.0 VGA compatible controller [0300]: Intel Corporation UHD Graphics 620 [8086:5917] (rev 07)
    Subsystem: Huawei Technologies Co., Ltd. UHD Graphics 620 [19e5:3e04]
$ sudo lshw | grep -i cpu
     *-cpu
          description: CPU
          product: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
          bus info: cpu@0
          version: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
          slot: CPU0
          capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d cpufreq
$ lscpu
Architecture:                    x86_64
CPU op-mode(s):                  32-bit, 64-bit
Byte Order:                      Little Endian
Address sizes:                   39 bits physical, 48 bits virtual
CPU(s):                          8
On-line CPU(s) list:             0-7
Thread(s) per core:              2
Core(s) per socket:              4
Socket(s):                       1
NUMA node(s):                    1
Vendor ID:                       GenuineIntel
CPU family:                      6
Model:                           142
Model name:                      Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
Stepping:                        10
CPU MHz:                         900.019
CPU max MHz:                     4000,0000
CPU min MHz:                     400,0000
BogoMIPS:                        3999.93
Virtualization:                  VT-x
L1d cache:                       128 KiB
L1i cache:                       128 KiB
L2 cache:                        1 MiB
L3 cache:                        8 MiB
NUMA node0 CPU(s):               0-7
Vulnerability Itlb multihit:     KVM: Mitigation: VMX disabled
Vulnerability L1tf:              Mitigation; PTE Inversion; VMX conditional cache flushes, SMT vulnerable
Vulnerability Mds:               Mitigation; Clear CPU buffers; SMT vulnerable
Vulnerability Meltdown:          Mitigation; PTI
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl and seccomp
Vulnerability Spectre v1:        Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2:        Mitigation; Full generic retpoline, IBPB conditional, IBRS_FW, STIBP conditional, RSB filling
Vulnerability Srbds:             Mitigation; Microcode
Vulnerability Tsx async abort:   Not affected
Flags:                           fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx p
                                 dpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 mo
$ sudo dmidecode | grep -A 9 "System Information"
System Information
    Manufacturer: HUAWEI
    Product Name: MACH-WX9
    Version: M14
    Serial Number:
    UUID:
    Wake-up Type: Other
    SKU Number: C128
    Family: MateBook X
Ubuntu 20.04: A couple of minutes browsing and a bit on youtube:
$ sudo turbostat --Summary --quiet --show Busy%,Bzy_MHz,IRQ,PkgWatt,PkgTmp --interval 10
Busy%   Bzy_MHz IRQ PkgTmp  PkgWatt
1.81    1831    33947   61  2.03
2.27    1603    61104   61  2.29
1.41    1707    25399   61  1.62
1.85    1605    37852   60  1.74
3.79    1946    30286   61  2.27
14.90   2565    90107   65  7.46
10.14   1660    83041   62  4.08
6.05    1693    20996   61  2.54
7.27    2296    56579   61  4.01
3.90    1651    35907   61  2.18
2.05    1189    4312    61  1.21
1.94    1178    3641    60  1.17
2.15    1193    8310    60  1.25
9.23    2368    71835   77  4.64
10.50   2345    100792  62  5.64
11.16   2301    103861  63  5.91
9.30    2056    87392   62  4.69
12.90   2458    101382  63  6.68
5.99    2456    85671   62  4.08
6.94    2583    84243   63  4.73
8.66    2602    70112   74  5.37
4.01    1634    82126   63  2.76
5.79    1916    69195   63  3.35
2.07    1440    46764   61  1.88
2.37    1849    19398   61  1.85
15.30   2763    103252  63  8.45
6.85    1619    91617   63  3.25
22.83   2673    113022  65  10.83
18.23   1953    80293   65  6.47
15.13   1833    18368   67  5.16
16.66   1937    31341   66  5.71
15.45   1841    19264   67  5.13
15.39   1883    25636   67  5.26
15.15   1841    18823   67  4.99
18.36   2194    38167   78  6.89
18.59   3148    25048   74  12.38
16.54   2872    20575   71  9.90
16.52   2827    19098   70  9.81
17.12   2737    25913   71  9.97
16.69   2597    20014   73  9.48
17.00   2530    19476   73  9.33
17.31   2483    20659   78  9.22
17.12   2515    19317   78  9.40
17.17   2492    19405   71  9.31
14.33   2440    28754   70  7.60
17.29   2475    100814  72  8.03
17.20   1717    88112   69  5.67
13.84   1454    21107   68  3.85
21.12   2390    95464   78  9.27
17.46   1958    83714   69  6.50
13.65   1621    17670   68  4.24
14.03   1677    31452   68  4.42
18.87   2151    63174   75  7.21
16.51   1760    108382  69  5.62
15.55   1736    93805   71  5.30
18.16   2097    106745  70  7.24
14.60   1759    103832  68  5.60
15.83   1826    38515   68  5.43
Ubuntu 18.04: A couple of minutes from idle to browsing and a bit on youtube + gather.town:
2.82    1768    46529   38  2.08
10.25   2147    60467   39  3.99
8.15    2114    75586   39  3.43
15.51   2082    89943   44  5.26
28.77   2033    135634  42  7.45
35.45   1387    119133  45  6.43
26.16   921 49050   42  4.57
20.72   841 27382   42  3.57
20.35   833 25787   41  3.52
20.99   840 25759   42  3.56
15.63   1490    65972   45  3.98
25.14   1867    138887  44  6.55
28.08   1272    75522   43  5.43
33.81   1484    89905   46  6.35
49.25   2158    212435  50  10.21
33.23   2167    142528  51  8.17
42.19   1965    147226  51  8.96
21.10   2083    112678  49  6.20
13.71   1535    71116   48  3.66
33.95   1441    115981  49  7.23
2.58    1272    11592   47  1.32
29.64   1331    75626   50  6.23
17.86   1094    25192   50  5.28
19.97   1168    43827   51  5.47
17.47   1786    35032   51  6.51
17.30   2052    24559   51  7.21
16.25   1824    23812   51  6.49
16.59   1405    23990   53  5.54
16.21   1642    24421   52  5.90
16.49   1556    24731   52  5.79
17.98   1739    35984   54  6.31
16.95   1723    26705   56  6.15
18.94   1782    34843   57  6.48
19.36   1647    37899   55  6.31
27.01   1701    69851   55  7.91
5.92    1410    55265   53  2.94
14.67   1683    94236   53  5.14
15.48   1982    96783   54  5.31
13.70   1799    104173  54  5.06
34.00   1584    191978  57  8.42
42.97   1597    144692  57  9.59
46.40   1364    146367  58  9.50
45.37   1195    145161  59  9.17
46.29   1111    152743  58  9.09
29.85   1344    169345  56  5.91
21.98   1397    134286  57  5.44
19.80   1454    120425  56  5.35
13.62   1320    113002  55  3.77
15.14   1292    115582  54  3.98
14.41   1283    113753  54  3.84
19.52   1135    116535  55  4.62
19.16   1378    123416  54  5.15
19.04   1438    117835  53  5.19
29.28   1566    191343  55  7.87
32.23   1315    150525  57  7.74
24.89   1511    178689  54  6.57
39.11   1435    126184  57  8.63
25.95   1438    87309   60  6.13
52.46   1569    157048  57  9.61
21.06   1876    43350   59  7.38
20.24   1834    52450   57  6.87
19.74   1549    40736   57  6.07
19.90   1854    43349   58  6.87
20.04   1448    43349   56  5.79
18.89   1658    46643   56  6.08
20.72   1136    44509   55  5.10
20.91   1615    56817   57  6.16
19.08   1682    44514   56  6.21
20.33   1480    46851   56  5.88
19.24   1878    44820   56  6.81
19.05   1620    46734   55  5.96
18.87   1719    46084   57  6.22
18.77   1589    43724   57  5.84
18.80   1646    46136   56  5.98
18.05   1654    44568   57  5.90
19.51   1495    43831   56  5.69
20.10   1425    47115   56  5.58
34.38   1278    107277  59  7.71
37.71   1461    150771  59  9.29
I now tried Ubuntu MATE 20.04 too (from idle to youtube+gather.town, a video thing):
sudo turbostat --Summary --quiet --show Busy%,Bzy_MHz,IRQ,PkgWatt,PkgTmp,GFXWatt --interval 10
[sudo] password for eris:
Busy%   Bzy_MHz IRQ PkgTmp  PkgWatt GFXWatt
0.52    1375    1665    46  0.63    0.00
0.81    1695    2413    46  0.75    0.00
3.06    2447    13288   47  1.79    0.00
16.00   3177    172104  51  9.36    0.00
25.35   3291    185541  72  14.66   0.00
18.26   3182    160839  55  10.76   0.00
17.86   3012    116988  65  9.22    0.00
23.82   3025    112455  68  12.28   0.00
23.10   2357    126068  67  8.70    0.00
19.91   1799    185705  60  5.62    0.00
23.89   2786    161790  70  10.65   0.00
28.50   3336    151280  73  15.69   0.00
27.92   3314    138395  74  15.58   0.00
32.25   3111    145045  72  15.35   0.00
19.68   2126    66127   67  7.43    0.00
18.63   2113    37507   66  6.93    0.00
19.86   2183    52183   67  7.69    0.00
19.08   2060    40849   69  6.96    0.00
19.01   2046    36192   69  6.86    0.00
20.27   2151    50647   71  7.52    0.00
31.72   3188    141914  76  15.35   0.00
