Linked to this question: How do I save terminal output to a file?
I understand that I can form an output file by using:
python3 script.py > output.txt
However, I also want to see the output being generated by the python file while it is being saved to output. Is there a simple way to do this on the command line?
Wychh
  • 111
Use a tee command. It is meant exactly for this.
python3 script.py | tee output.txt
It can also be done in more complicated way. Run your original command in the background and simultaneusly view the contents of file output.txt in the foreground. I sometimes prefer to do it that way, especially for long-running processes, since I can at any time abort viewing of the output file and return to it anytime later:
python3 script.py > output.txt &
tail -f output.txt
(you can Ctrl-C in the tail command at any time, and run again the command later).
raj
  • 11,409
