What you are doing here is ambiguous even in bash.
In bash, if the noglob option is not set and mate-* matches one or more files in the current directory, it will be expanded to a list of those files which will be passed as arguments to apt-get remove. Otherwise, it will be passed literally to the apt-get command unless:
- the
failglob option is set, in which case the behavior will be the same as in fish
- the
nullglob option is set, in which case mate-* will be removed altogether
In fish, the behavior appears to be equivalent to bash's failglob, and there does not seem to be an equivalent of bash's set -o noglob or set -f. So you will need to prevent globbing explicitly by quoting, ex.
sudo apt-get remove "mate-*"
or
sudo apt-get remove mate-"*"
(which you really should be doing in bash, for the reasons outlined above).
See also:
Also be aware that apt has moved away from simple wildcards altogether in favor of aptitude-style patterns - see Problem using wildcard with apt.
