I'm trying to upgrade my Ubuntu version 20.04.2 LTS to 20.10 so that I could finally upgrade it to 21.04 (Hirsute Hippo)
Once I run the upgrade command, I get this unmet dependency error:
$ sudo apt-get upgrade
Reading package lists... Done Building dependency tree
Reading state information... Done You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: libsmbclient : Depends: samba-libs (= 2:4.11.6+dfsg-0ubuntu1.8) but 2:4.11.6+dfsg-0ubuntu1.6 is installed samba-libs : Depends: libwbclient0 (= 2:4.11.6+dfsg-0ubuntu1.6) but 2:4.11.6+dfsg-0ubuntu1.8 is installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
And when I try:
$ sudo apt --fix-broken install
Reading state information... Done Correcting dependencies... Done The following package was automatically installed and is no longer required: libllvm10 Use 'sudo apt autoremove' to remove it. The following additional packages will be installed: samba-libs The following packages will be upgraded: samba-libs 1 upgraded, 0 newly installed, 0 to remove and 25 not upgraded. 1 not fully installed or removed. Need to get 0 B/5,282 kB of archives. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] E: Invalid archive member header E: Prior errors apply to /var/cache/apt/archives/samba-libs_2%3a4.11.6+dfsg-0ubuntu1.8_amd64.deb debconf: apt-extracttemplates failed: No such file or directory (Reading database ... 215241 files and directories currently installed.) Preparing to unpack .../samba-libs_2%3a4.11.6+dfsg-0ubuntu1.8_amd64.deb ... Unpacking libwbclient0:amd64 (2:4.11.6+dfsg-0ubuntu1.8) over (2:4.11.6+dfsg-0ubuntu1.8) ... Setting up libwbclient0:amd64 (2:4.11.6+dfsg-0ubuntu1.8) ... dpkg: dependency problems prevent configuration of libsmbclient:amd64: libsmbclient:amd64 depends on samba-libs (= 2:4.11.6+dfsg-0ubuntu1.8); however: Version of samba-libs:amd64 on system is 2:4.11.6+dfsg-0ubuntu1.6.
dpkg: error processing package libsmbclient:amd64 (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup error from a previous failure. Processing triggers for libc-bin (2.31-0ubuntu9.2) ... Errors were encountered while processing: libsmbclient:amd64 E: Sub-process /usr/bin/dpkg returned an error code (1)
I want to eventually run sudo do-release-upgrade but before that I have to install all available updates for the release. How further to proceed?
From your output:
This means that your samba-libs package is corrupt. Delete it from your local cache, and let apt download a fresh copy.
sudo rm /var/cache/apt/archives/samba-libs_2%3a4.11.6+dfsg-0ubuntu1.8_amd64.deb
    # The file path/name is provided by the error message.
sudo apt update sudo apt upgrade # Apt will automatically detect that the package is missing and download it.
user535733
  • 68,493
