since 16.04 reached EOL I wanted to upgrade to 18.04 but after automatically restarting at the end of the upgrade, my laptop (Dell XPS 13 9360) did not connect to the internet. The wifi settings state "No wi-fi adapter found". Pinging anything gives me connect: Network is unreachable and running rfkill list all only shows Bluetooth but no wifi. The only output I get is
0: hci0: Bluetooth Soft blocked: no Hard blocked: no. No mention of Wireless LAN.
Output of lshw -C network
*-network
description: Network controller
product: QCA6174 802.11ac Wireless Network Adapter
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:3a:00.0
version: 32
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=ath10k_pci latency=0
resources: irq:135 memory:dc000000-dc1fffff
Output for lspci -knn | grep Net -A3:
3a:00.0 Network controller [02880]: Qualcomm Atheros QA6174 802.11ac
Wireless Network Adapter [168c:003e] (rev32)
Subsystem: Bigfoot Networks, Inc. QA6174 802.11ac Wireless Network Adapter [1a56:1535]
Kernel driver in use: ath10k_pci
Kernel modules: ath10k_pci
3b:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader [10ec:525a] (rev 01)
And dmesg | grep ath10k:
[ 4.347504] ath10k_pci 0000:3a:00.0: enabling device (0000 -> 0002)
[ 4.351838] ath10k_pci 0000:3a:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 4.642560] ath10k_pci 0000:3a:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:3a:00.0.bin failed with error -2
[ 4.642572] ath10k_pci 0000:3a:00.0: Direct firmware load for ath10k/cal-pci-0000:3a:00.0.bin failed with error -2
[ 4.643324] ath10k_pci 0000:3a:00.0: Direct firmware load for ath10k/QA6174/hw3.0/firmware-6.bin failed with error -2
[ 4.643341] ath10k_pci 0000:3a:00.0: Direct firmware load for ath10k/QA6174/hw3.0/firmware-5.bin failed with error -2
[ 4.643347] ath10k_pci 0000:3a:00.0: Direct firmware load for ath10k/QA6174/hw3.0/firmware-4.bin failed with error -2
[ 4.643353] ath10k_pci 0000:3a:00.0: Direct firmware load for ath10k/QA6174/hw3.0/firmware-3.bin failed with error -2
[ 4.643359] ath10k_pci 0000:3a:00.0: Direct firmware load for ath10k/QA6174/hw3.0/firmware-2.bin failed with error -2
[ 4.643361] ath10k_pci 0000:3a:00.0: Failed to find firmware-N.bin (N between 2 and 6) from ath10k/QCA6174/hw3.0: -2
[ 4.643364] ath10k_pci 0000:3a:00.0: could not fetch firmware files (-2)
[ 4.643366] ath10k_pci 0000:3a:00.0: could not probe fw (-2)
Also, the command sudo iw dev gives me no output at all but trying to install iw gives me iw is already the newest version (4.14-0.1).
I tried the first method from here, downloaded the iso on my phone, transfered it on my laptop but was not able to mount it as running sudo mount -o loop ubuntu-* /media/cdrom gave me mount: ubuntu-*/media/cdrom: can't find in /etc/fstab. I understand that the formatting is different in /etc/fstab and that's why it can't follow but I don't know how to fix it on my own.
I'm sorry if this is a mess, this is the first time I couldn't fix a problem with the questions already solved and need guidance as I am as dense as a neutron star when it comes to computers.
UPDATE: After running sudo apt install --reinstall linux-firmware
(and upgrading to 20.04 beforehand) wifi shows up in drop down menu and is listed when rfkill list all is run (with soft and hard block set to no).
Now the output of sudo iw dev is
phy#0
Interface wlp58s0
ifindex 2
wdev 0x1
addr 9c:b6:d0:f5:2c:fd
type managed
txpower 0.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
And dmesg | grep ath10k changed to:
[ 4.173183] ath10k_pci 0000:3a:00.0: enabling device (0000 -> 0002)
[ 4.175431] ath10k_pci 0000:3a:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 4.465655] ath10k_pci 0000:3a:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 1a56:1535
[ 4.465674] ath10k_pci 0000:3a:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[ 4.469191] ath10k_pci 0000:3a:00.0: firmware ver WLAN.RM.4.4.1-00140-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 29eb8ca1
[ 4.559357] ath10k_pci 0000:3a:00.0: board_file api 2 bmi_id N/A crc32 4ac0889b
[ 4.658875] ath10k_pci 0000:3a:00.0: unsupported HTC service id: 1536
[ 4.685903] ath10k_pci 0000:3a:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 6.224867] ath10k_pci 0000:3a:00.0 wlp58s0: renamed from wlan0
[ 7.382626] ath10k_pci 0000:3a:00.0: unsupported HTC service id: 1536
I am still missing the drivers for my wifi adapter and currently have no clue where to find them.
UPDATE 2: I came across this and followed the steps and still nothing. The outputs for dmesg and iw dev remain the same BUT now rfkill list all says that my wifi is soft blocked:
0: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
and to be honest, I don't know if this is a step forward or back.
