The following error is returned:
Reading package lists... Done
Building dependency tree
build-essential : Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: g++ (>= 4:9.2) but it is not going to be installed
I have tried sudo apt-get update and sudo apt install cmake but the error is the same.
The output of apt-cache policy build-essential libc6-dev libc6 libc-dev g++ cmake
build-essential:
Installed: (none)
Candidate: 12.8ubuntu1
Version table:
12.8ubuntu1 500
500 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages
libc6-dev:
Installed: (none)
Candidate: 2.31-0ubuntu9
Version table:
2.31-0ubuntu9 500
libc6:
Installed: 2.31-0ubuntu9.3
Candidate: 2.31-0ubuntu9.3
Version table:
*** 2.31-0ubuntu9.3 100
100 /var/lib/dpkg/status
2.31-0ubuntu9 500
libc-dev:
Installed: (none)
Candidate: (none)
Version table:
g++:
Installed: (none)
Candidate: 4:9.3.0-1ubuntu2
Version table:
4:9.3.0-1ubuntu2 500
cmake:
Installed: 3.16.3-1ubuntu1
Candidate: 3.16.3-1ubuntu1
Version table:
*** 3.16.3-1ubuntu1 500
Output of sudo apt update
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://ppa.launchpad.net/jonmagon/kdiskmark/ubuntu focal InRelease
Hit:3 http://dl.google.com/linux/chrome/deb stable InRelease
Ign:4 http://repo.vivaldi.com/stable/deb stable InRelease
Hit:5 http://packages.microsoft.com/repos/code stable InRelease
Hit:6 http://apt.insync.io/ubuntu focal InRelease
Hit:7 http://repo.vivaldi.com/stable/deb stable Release
Hit:8 https://download.docker.com/linux/ubuntu focal InRelease
Hit:9 https://download.sublimetext.com apt/stable/ InRelease
** grep ^deb -r /etc/apt/ --include=*.list **
said@~/Projects/Rust/hello_world$ grep ^deb -r /etc/apt/ --include=*.list
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu focal main universe restricted
/etc/apt/sources.list:deb-src http://archive.ubuntu.com/ubuntu focal main universe restricted #Added by software-properties
/etc/apt/sources.list.d/insync.list:deb http://apt.insync.io/ubuntu/ focal non-free contrib
/etc/apt/sources.list.d/vivaldi.list:deb http://repo.vivaldi.com/stable/deb/ stable main
/etc/apt/sources.list.d/google-chrome.list:deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
/etc/apt/sources.list.d/jonmagon-ubuntu-kdiskmark-focal.list:deb http://ppa.launchpad.net/jonmagon/kdiskmark/ubuntu/ focal main
/etc/apt/sources.list.d/vscode.list:deb [arch=amd64,arm64,armhf] http://packages.microsoft.com/repos/code/ stable main
/etc/apt/sources.list.d/docker.list:deb [arch=amd64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu/ focal stable
/etc/apt/sources.list.d/sublime-text.list:deb https://download.sublimetext.com/ apt/stable/
Update:
I had to reinstall Kubuntu 20.04. It was dirty installation in which formatting of / and /boot mount points had been occurred but /home left as it is and then creating the user with the same name of the previous installation to keep home settings intact.
I think this a major drawback of Debian based distros apt. I think that it is not found for Fedora dnf or OpenSuse yum. However, I think that the usage of apt install should be preceded by apt update and even the installation from *.deb files too.
