Update: Solved by going to the Settings on the Update Manager and deselecting all the source checkboxes and changing the source to Main Server.
A while back I had considerable difficulty upgrading my system from 19.04 to 20.04 and after it updated itself to 19.10 Eoan the lingering affects of multiple errors seem to keep it from updating so apparently the upgrade did not do everything it was supposed to do. For example, there a couple held packages that do not update and I've tried so many different things that I've forgotten what they were so apologies if this seems disjointed but I'll gladly update it with advice on what to do or try.
It was pointed out that there is a similar question about held packages and indeed that is the problem here too but the main issue is the Eoan reference and how to fix the overall update which failed on several levels, only part of which are the held packages.
Although I can't locate them at the moment, some of the errors related to 19.10 Eoan which I mentioned in the title and perhaps that's normal but I don't believe there should be such references.
apt list --upgradable
Listing... Done
mysql-client/focal-updates,focal-updates,focal-security,focal-security 8.0.23-0ubuntu0.20.04.1 amd64 [upgradable from: 8.0.19-1ubuntu19.10]
mysql-server/focal-updates,focal-updates,focal-security,focal-security 8.0.23-0ubuntu0.20.04.1 amd64 [upgradable from: 8.0.19-1ubuntu19.10]
Some of the issues manifest themselves in not being able to update MySQL. Checking which version of mysql is installed . . .
mysql -V
mysql  Ver 8.0.19 for Linux on x86_64 (MySQL Community Server - GPL)
it gives gives errors when I try to upgrade it:
sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  mysql-client mysql-server
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
There are also unmet dependencies that so not seem to want to update:
sudo apt install mysql-client
The following packages have unmet dependencies: mysql-client : Depends: mysql-client-8.0 but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Other issues relating to WINE having stopped working (WINE applications do nothing when selected) and it seems to want Win32 which will not install.
sudo apt-get install wine32
The following packages have unmet dependencies: wine32:i386 : Depends: libwine:i386 (= 5.0-3ubuntu1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Of course I tried installing the dependencies separately but that also gives other errors as it seems that each depends upon something else.
I also installed and ran aptitude which corrected many things but not the held packages.
Update: In spite mysql and WINE errors, those packages seem to run.
Ideas?
DonP
  • 492
