I have an old computer that doesn't support the newest versions of Chromium, since the CPU lacks the support of SSE3 instructions (I saw that in a forum).
Recently, I have updated Chromium and version 89 was installed, and then stopped working (Illegal instruction error).
Which commands should I run in order to reinstall an older version of chromium (e.g. 65.0.3325.181-0ubuntu1), which doesn't contain SSE3 instructions?
Did anyone experience this also?
Of course, in order to install an older version of Chromium, I have to make sure that all the dependencies are installed in the correct version, and not in a newer version...
EDIT:
After uninstalling Chromium (sudo apt remove all the packages below), I ran:
sudo apt install chromium-browser=65.0.3325.181-0ubuntu1 chromium-codecs-ffmpeg-extra=65.0.3325.181-0ubuntu1 chromium-codecs-ffmpeg=65.0.3325.181-0ubuntu1 chromium-browser-l10n=65.0.3325.181-0ubuntu1
Reading package lists... Done
Building dependency tree
chromium-codecs-ffmpeg : Conflicts: chromium-codecs-ffmpeg-extra but 65.0.3325.181-0ubuntu1 is to be installed
chromium-codecs-ffmpeg-extra : Conflicts: chromium-codecs-ffmpeg but 65.0.3325.181-0ubuntu1 is to be installed
As you see, my installation has some kind of problem...
How can I solve this?
By the way, I have a functional Firefox browser in my old computer, fortunately...
