After installing odoo from apt I cannot seem to get to a welcome page:
Starting odoo:
nicholas@mordor:~$
nicholas@mordor:~$ odoo --xmlrpc-port=8000
2021-05-01 04:32:16,518 81810 INFO ? odoo: Odoo version 14.0-20210430
2021-05-01 04:32:16,519 81810 INFO ? odoo: addons paths: ['/usr/lib/python3/dist-packages/odoo/addons', '/home/nicholas/.local/share/Odoo/addons/14.0']
2021-05-01 04:32:16,519 81810 INFO ? odoo: database: default@default:default
2021-05-01 04:32:16,639 81810 INFO ? odoo.addons.base.models.ir_actions_report: You need Wkhtmltopdf to print a pdf version of the reports.
2021-05-01 04:32:16,698 81810 WARNING ? odoo.addons.base.models.res_currency: The num2words python library is not installed, amount-to-text features won't be fully available.
2021-05-01 04:32:16,721 81810 INFO ? odoo.service.server: HTTP service (werkzeug) running on mordor.saundersconsulting.tech:8000
trying to access the home page:
nicholas@mordor:~$
nicholas@mordor:~$ lynx --dump localhost:8000
Internal Server Error
The server encountered an internal error and was unable to complete
your request. Either the server is overloaded or there is an error in
the application.
nicholas@mordor:~$
which generates more errors. Full log:
nicholas@mordor:~$
2021-05-01 04:32:39,450 81810 INFO ? odoo.http: HTTP Configuring static files
2021-05-01 04:32:39,455 81810 INFO ? odoo.sql_db: Connection to the database failed
2021-05-01 04:32:39,457 81810 INFO ? werkzeug: 127.0.0.1 - - [01/May/2021 04:32:39] "GET / HTTP/1.0" 500 - 0 0.000 0.005
2021-05-01 04:32:39,460 81810 ERROR ? werkzeug: Error on request:
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/werkzeug/serving.py", line 323, in run_wsgi
execute(self.server.app)
File "/usr/lib/python3/dist-packages/werkzeug/serving.py", line 312, in execute
application_iter = app(environ, start_response)
File "/usr/lib/python3/dist-packages/odoo/service/server.py", line 440, in app
return self.app(e, s)
File "/usr/lib/python3/dist-packages/odoo/service/wsgi_server.py", line 124, in application
return application_unproxied(environ, start_response)
File "/usr/lib/python3/dist-packages/odoo/service/wsgi_server.py", line 99, in application_unproxied
result = odoo.http.root(environ, start_response)
File "/usr/lib/python3/dist-packages/odoo/http.py", line 1295, in __call__
return self.dispatch(environ, start_response)
File "/usr/lib/python3/dist-packages/odoo/http.py", line 1263, in __call__
return self.app(environ, start_wrapped)
File "/usr/lib/python3/dist-packages/werkzeug/middleware/shared_data.py", line 260, in __call__
return self.app(environ, start_response)
File "/usr/lib/python3/dist-packages/odoo/http.py", line 1429, in dispatch
self.setup_db(httprequest)
File "/usr/lib/python3/dist-packages/odoo/http.py", line 1352, in setup_db
httprequest.session.db = db_monodb(httprequest)
File "/usr/lib/python3/dist-packages/odoo/http.py", line 1517, in db_monodb
dbs = db_list(True, httprequest)
File "/usr/lib/python3/dist-packages/odoo/http.py", line 1484, in db_list
dbs = odoo.service.db.list_dbs(force)
File "/usr/lib/python3/dist-packages/odoo/service/db.py", line 384, in list_dbs
with closing(db.cursor()) as cr:
File "/usr/lib/python3/dist-packages/odoo/sql_db.py", line 675, in cursor
return Cursor(self.__pool, self.dbname, self.dsn, serialized=serialized)
File "/usr/lib/python3/dist-packages/odoo/sql_db.py", line 248, in __init__
self._cnx = pool.borrow(dsn)
File "/usr/lib/python3/dist-packages/odoo/sql_db.py", line 558, in _locked
return fun(self, *args, **kwargs)
File "/usr/lib/python3/dist-packages/odoo/sql_db.py", line 624, in borrow
result = psycopg2.connect(
File "/usr/lib/python3/dist-packages/psycopg2/__init__.py", line 127, in connect
conn = _connect(dsn, connection_factory=connection_factory, **kwasync)
psycopg2.OperationalError: FATAL: role "nicholas" does not exist - - -
