I have a big problem, I was trying to use Python3 on my PC and it seemed like Python3 wasn't there, I tried installing it and it said Python3 is already installed.
So I uninstalled python3 and reinstalled it, that's when everything stopped functioning properly, then I rebooted the PC and it showed a long log then got stuck and doesn't even reach the lock screen.
I firstly ran 'sudo apt update'. Then ran 'sudo apt install software-properties-common' and it successfully installed. Next I ran 'sudo add-apt-repository ppa:deadsnakes/ppa' After I ran 'sudo apt update' again.
second step I ran 'sudo apt install python3.8' Out put indicated that python3.8 is already installed. When checking the version with 'python ––version' Output was "command not found"
That's when I ran 'sudo apt remove python3.8' then after that 'sudo apt install python3.8' It did install some of the files and finished but things stopped functioning.
I would show the log if I knew how
