i'm new in linux and i got a problem: can't install mysql after downloading mysql-apt-config_0.8.17-1_all.deb from mysql official page and configuring it using:
sudo dpkg -i mysql-apt-config_0.8.17-1_all.deb i got:
(Reading database ... 360760 files and directories currently installed.)
Preparing to unpack .../mysql-apt-config_0.8.17-1_all.deb ...
Unpacking mysql-apt-config (0.8.17-1) over (0.8.17-1) ...
Setting up mysql-apt-config (0.8.17-1) ...
Warning: apt-key should not be used in scripts (called from postinst maintainerscript of the package mysql-apt-config)
OK
sudo dpkg-reconfigure mysql-apt-config i got:
OK
and when typing sudo apt install mysql-server i got:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: mysql-server : Depends: mysql-community-server (= 8.0.24-1ubuntu16.04) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I was looking on internet the way to fix this, but i can't find the solution.
I'm using Linux Mint
Updates:
run the command lsb_release -cs to print your version.
lsb_release -cs
However, you should be using apt to install instead of dpkg like this sudo apt install ./mysql-apt-config_0.8.17-1_all.deb
using: sudo apt install ./mysql-apt-config_0.8.17-1_all.deb
[sudo] password for dev:
Note, selecting 'mysql-apt-config' instead of './mysql-apt-config_0.8.17-1_all.deb'
mysql-apt-config is already the newest version (0.8.17-1).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
josmanuel
  • 129
mysql repository is misconfigured because the used codename is xenial instead of focal. Use the following command to fix mysql repository (Ulyssa is based on Focal):
sudo sed -i 's/xenial/focal/g' /etc/apt/sources.list.d/mysql.list
Then run:
sudo apt update
GAD3R
  • 3,748
