I am currently using gdm3 destop manager while I login it gets stuck in login loop.
  • I have followed almost all the procedures suggested in this post
  • Permissions of Xauthority and /tmp were fine.
  • Added sudo add-apt-repository ppa:graphics-drivers/ppa and updated after it as well.
But none of them worked.
I created a new user when I try to login through it there is no login loop. I am able to login properly. Why am I not able to use the original user. I'm really not understanding what to do. Can someone please help.
Since you are able to login to Gnome Shell using the new user you had created, this implies that the issue is with your existing user, and not a Gnome Shell issue. (Issues with Gnome Shell usually have similar symptoms).
Check if there are any files not owned by you in your home directory.
Login using CtrlAltF3, again, and execute the following:
find $HOME -not -user $USER -exec ls -lad {} \;
Option 1: Fix These File Permissions
  1. For each file or directory NOT owned by you, execute:
    sudo chown -R $USER:$USER <file or directory path>
    Based on your comment above, you can execute the following commands on the parent directories:
    sudo chown -R $USER:$USER ~/.cache
    sudo chown -R $USER:$USER ~/dbus
  2. Then, see if you can successfully login to your desktop environment.
Option 2: Remove These Files
I don't think think you should have these files (.cache/dconf, .cache/doc, and dbus) in your home directory at all. I suspect that you ran a graphical program as root. If you have done this, never run any graphical program using sudo. (Insetad, use the admin: parameter; for example nautilus admin:/path/to/directory).
In any case Ubuntu should run fine without the .cache/dconf, .cache/doc, and dbus files or directories.
  1. Try removing these files to a backup location.
    sudo mkdir /home/temp
    sudo mv ~/.cache/dconf /home/temp
    sudo mv ~/.cache/doc /home/temp
    sudo mv ~/dbus /home/temp
  3. If everything works, delete the backed up files.
    sudo rm -rf /home/temp
Enterprise
  • 12,792
