Error when upgraded operating system from Ubuntu 16.04 to 18.04> do-release-upgrade
Current version:
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.7 LTS"
Any body faced this issue ? Is there a solution to this ?
**do-release-upgrade -f DistUpgradeViewNonInteractive**
Send problem report to the developers?
After the problem report has been sent, please fill out the form in the automatically opened web browser.
What would you like to do? Your options are: S: Send report (302.5 KB) V: View report K: Keep report file for sending later or copying to somewhere else I: Cancel and ignore future crashes of this program version C: Cancel Please choose (S/V/K/I/C): Traceback (most recent call last): File "/usr/bin/apport-cli", line 386, in <module> if not app.run_argv(): File "/usr/lib/python3/dist-packages/apport/ui.py", line 673, in run_argv return self.run_report_bug() File "/usr/lib/python3/dist-packages/apport/ui.py", line 511, in run_report_bug response = self.ui_present_report_details(allowed_to_report) File "/usr/bin/apport-cli", line 213, in ui_present_report_details response = dialog.run() File "/usr/bin/apport-cli", line 101, in run multi_char) File "/usr/bin/apport-cli", line 49, in raw_input_char saved_attributes = termios.tcgetattr(file) termios.error: (25, 'Inappropriate ioctl for device')
var log errors
/var/log/dist-upgrade/main.log
2021-04-27 15:31:12,436 ERROR No 'ubuntu-minimal' available/downloadable after sources.list rewrite+update 2021-04-27 15:31:12,436 ERROR 'ubuntu-minimal' was not downloadable 2021-04-27 15:31:12,436 ERROR Invalid package information After updating your package information, the essential package 'ubuntu-minimal' could not be located. This may be because you have no official mirrors listed in your software sources, or because of excessive load on the mirror you are using. See /etc/apt/sources.list for the current list of configured software sources. In the case of an overloaded mirror, you may want to try the upgrade again later. (None) 2021-04-27 15:31:12,448 DEBUG abort called
unknown
  • 99
