ISSUE
Originally my motherboard was working fine with only Windows. After adding a separate Ubuntu SSD, my ethernet LAN port has stopped being recognised, both by Windows and by Ubuntu. I don't think it is a duplicate of the many driver issues seen on askubuntu, as I explored that, but I can't confirm if it's a problem with the board itself or something else I don't understand.
If you need ANY more information, either from Windows or from Ubuntu, will share whatever's needed.
PC Specs:
  • OSs - Ubuntu 20.04.2 LTS x86_64 + Windows 10
  • Kernel - 5.8.0-50-generic
  • CPU - Ryzen 7 5800x
  • Mobo - Gigabyte Aorus B550 Elite AX V2 - link here
  • Disks - 1 Samsung 980 PRO 1 TB PCIe 4.0 (Windows 10), 1 Samsung 970 EVO Plus 1 TB PCIe 3.0 (Ubuntu 20.04)
  • GPU - Nvidia RTX 3080 FE
  • RAM - 32GB (2x16GB) Corsair DDR4 Vengeance LPX
Steps Taken:
  1. Other similar posts have said it might be a driver issue. Following posts similar to this one here I manually installed Realtek drivers on Ubuntu and Windows. This did not solve the problem.
  2. sudo lshw -C network does not show the Ethernet as being available. I think what I should see here is something like: *-network UNCLAIMED description: Ethernet controller product: RTL8125 2.5GbE Controller but that doesn't show:
    ~ ❯ sudo lshw -C network
      *-network
       description: Wireless interface
       product: Wi-Fi 6 AX200
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: wlp6s0
       version: 1a
       serial: c8:b2:9b:a1:1a:3a
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=5.8.0-50-generic firmware=55.d9698065.0 cc-a0-55.ucode ip=192.168.0.22 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:38 memory:fc500000-fc503fff
  3. Tested the ethernet cable from my router on a Mac, worked perfectly fine, so it's not a cable issue.
  4. Disabled all sorts of FastBoot, Wake-From-LAN etc etc in both Windows and BIOS, no changes
  5. cat /etc/netplan/01-network-manager-all.yaml:
    # Let NetworkManager manage all devices on this system
    network:
      version: 2
      renderer: NetworkManager
  6. sudo ip a
    ~ ❯ sudo ip a
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
    2: wlp6s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether c8:b2:9b:a1:1a:3a brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.22/24 brd 192.168.0.255 scope global dynamic noprefixroute wlp6s0
       valid_lft 84463sec preferred_lft 84463sec
    inet6 fe80::63a6:76c2:cb97:be14/64 scope link noprefixroute
  7. cat /etc/NetworkManager/NetworkManager.conf
    ~ ❯ cat /etc/NetworkManager/NetworkManager.conf
    [main]
    plugins=ifupdown,keyfile
    [ifupdown] managed=true
    [device] wifi.scan-rand-mac-address=no
  8. lspci -knn:
    ~ ❯ lspci -knn
    00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex [1022:1480]
            Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex [1022:1480]
    00:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU [1022:1481]
            Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU [1022:1481]
    00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
    00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
            Kernel driver in use: pcieport
    00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
    00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
    00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
    00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
    00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
    00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
    00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
    00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
    00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
    00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
    00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
            Subsystem: Gigabyte Technology Co., Ltd FCH SMBus Controller [1458:5001]
            Kernel modules: i2c_piix4, sp5100_tco
    00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
            Subsystem: Gigabyte Technology Co., Ltd FCH LPC Bridge [1458:5001]
    00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0 [1022:1440]
    00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1 [1022:1441]
    00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2 [1022:1442]
    00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3 [1022:1443]
            Kernel driver in use: k10temp
            Kernel modules: k10temp
    00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4 [1022:1444]
    00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5 [1022:1445]
    00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6 [1022:1446]
    00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7 [1022:1447]
    01:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd Device [144d:a80a]
            Subsystem: Samsung Electronics Co Ltd Device [144d:a801]
            Kernel driver in use: nvme
            Kernel modules: nvme
    02:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:43ee]
            Subsystem: ASMedia Technology Inc. Device [1b21:1142]
            Kernel driver in use: xhci_hcd
            Kernel modules: xhci_pci
    02:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] Device [1022:43eb]
            Subsystem: ASMedia Technology Inc. Device [1b21:1062]
            Kernel driver in use: ahci
            Kernel modules: ahci
    02:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43e9]
    03:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43ea]
    03:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43ea]
    03:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43ea]
    04:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808]
            Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a801]
    06:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
            Subsystem: Intel Corporation Wi-Fi 6 AX200 [8086:0084]
            Kernel driver in use: iwlwifi
            Kernel modules: iwlwifi
    07:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:2206] (rev a1)
            Subsystem: NVIDIA Corporation Device [10de:1467]
            Kernel driver in use: nvidia
            Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
    07:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:1aef] (rev a1)
            Kernel driver in use: snd_hda_intel
            Kernel modules: snd_hda_intel
    08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
            Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
    09:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
            Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
    09:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
            Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
            Kernel driver in use: ccp
            Kernel modules: ccp
    09:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
            Subsystem: Gigabyte Technology Co., Ltd Matisse USB 3.0 Host Controller [1458:5007]
    09:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
            DeviceName: Realtek ALC1220
            Subsystem: Gigabyte Technology Co., Ltd Starship/Matisse HD Audio Controller [1458:a0cf]
    ~ ❯ lspci -knn | grep eth
  9. Reached out to Gigabyte Technical Support. They suggested to upgrade BIOS from F12 to F13h. This did not solve the problem.
Conclusions
I am not familiar with Windows AT ALL (only use for Steam gaming), but after doing some Googling, I think the same issue applies there, where the Ethernet Network Adaptor does not exist or can't be detected. I would like to stress, it was available in the past, but now is not. The same applies on Ubuntu, so for both OSs, installing the Drivers doesn't solve the problem because it's not detected as existing in the first place.
What I would love, is either a solution to this if anyone has any ideas, or confirmation that it's a hardware fault so I can return my MOBO or buy some additional PCIEX Network adapter
Marc
If you can somehow try to find what device you have as a network adapter - name, id. If it was shown in windows and working all the time for sure it has to be present in linux - if it's not psychically damaged or old, or missing. After that try to find a good driver for it, depending on your kernel/linux. In my case, i shared internet via usb from the phone, and downloaded via pamac/pacman one of the drivers available for the kernel and device i was using. But of course i had to spend some night hours exploring my inexperience with linux, messing up the network manager config to unusable, install and uninstalling drivers or trying to compile a driver while not having internet and transfering files via usb stick because somehow internet was working there. Yeah, i like drivers and linux. Anyways, linux is cool. Still would stick around.
