After solving my graphics issue with help from here: Blank (no signal) display on new ASUS Z590 motherboard
And helping someone else out here: UnclaImed display in ubuntu 21.04 with Rocket Lake
I have an issue with my 11900k "powersave" govenor (cpupower) only allowing a max of 4.7ghz. If I manually change it to "performance" using cpupower-gui I can clock up to 5.3ghz and 5.1 on heavy AVX using s-tui just like my motherboard is set for.
Is there a way to "fix" the powersave governor built into this oem kernel to allow max speed in powersave mode? Because under performance mode it's constantly revved up to over 5ghz and running a little hotter. I've searched all over for microcode to no avail. I am clueless about modifying kernels.
Side note: I will ask in a separate thread: iperf is showing my 2.5gb NIC running only at gigabit speed tested against a known 2.5gb connection (works with other PCs at full speed).
Seem like we are needing some actual linux drivers from Intel, what gives?
Update to add inxi output:
CPU: 8-Core 11th Gen Intel Core i9-11900K (-MT MCP-)
speed/min/max: 3726/800/5300 MHz Kernel: 5.10.0-1023-oem x86_64 Up: 1h
05m
Mem: 1485.8/64079.5 MiB (2.3%) Storage: 11.94 TiB (12.7% used) Procs:
369
Shell: bash 5.0.17 inxi: 3.0.38
^^^ That storage output is odd as well, only showing my hardware raid array an not my 3 NVMe drives
UPDATE: I installed kernel 5.12. Initially I thought I couldn't boot into it until I moved one of my monitors cables to my discrete GPU. It boots up on the onboard graphics then that just shows a blinking cursor and the gpu connected monitor takes over for a single monitor desktop. Still the same issue with the CPU governor speeds and still no 2.5G ethernet.
Update 2: per Doug Smythies request Before Grub change:
grep . /sys/devices/system/cpu/intel_pstate/*
/sys/devices/system/cpu/intel_pstate/hwp_dynamic_boost:0
/sys/devices/system/cpu/intel_pstate/max_perf_pct:100
/sys/devices/system/cpu/intel_pstate/min_perf_pct:15
/sys/devices/system/cpu/intel_pstate/no_turbo:0
/sys/devices/system/cpu/intel_pstate/num_pstates:46
/sys/devices/system/cpu/intel_pstate/status:active
/sys/devices/system/cpu/intel_pstate/turbo_pct:40
After Grub change:
chris@pc-01:~$ grep . /sys/devices/system/cpu/cpu*/cpufreq/scaling_m*
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu10/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu10/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu11/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu11/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu12/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu12/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu13/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu13/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu14/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu14/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu15/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu15/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu5/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu5/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu6/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu6/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu7/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu7/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu8/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu8/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu9/cpufreq/scaling_max_freq:5300000
/sys/devices/system/cpu/cpu9/cpufreq/scaling_min_freq:800000
Also after grub update:
chris@pc-01:~$ grep . /sys/devices/system/cpu/intel_pstate/*
s-tui no change. I did something with systemctl to force it to boot to performance mode. Disabled ondemand as I recall. Performance mode reports 5000mhz, correct per my bios setting for heavy AVX, powersave still at 4700mhz
Output of cpupower frequency-info
chris@pc-01:~$ sudo cpupower frequency-info
analyzing CPU 0:
driver: intel_pstate
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency:  Cannot determine or is not supported.
hardware limits: 800 MHz - 5.30 GHz
available cpufreq governors: performance powersave
current policy: frequency should be within 800 MHz and 5.30 GHz.
              The governor "powersave" may decide which speed to use
              within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 2.20 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
Turbostat outputs:
chris@pc-01:~$ sudo turbostat --Summary --quiet --show
Busy%   Bzy_MHz IRQ PkgTmp  PkgWatt GFXWatt RAMWatt PKG_%
0.37    5176    40647   32  21.14   0.01    0.00    0.00
0.37    5165    40647   33  21.26   0.01    0.00    0.00
0.37    5157    39663   32  21.19   0.01    0.00    0.00
0.36    5163    39501   33  21.27   0.01    0.00    0.00
0.37    5168    41354   32  21.17   0.01    0.00    0.00
0.38    5161    42241   32  21.37   0.01    0.00    0.00
0.39    5167    5869    33  21.51   0.01    0.00    0.00
1.07    1393    42633   31  17.42   0.01    0.00    0.00
1.06    1435    43711   32  17.52   0.01    0.00    0.00
1.08    1397    41036   32  17.41   0.01    0.00    0.00
1.08    1389    41864   32  17.40   0.01    0.00    0.00
1.16    1390    19255   33  17.48   0.01    0.00    0.00
So it's costing me more like 4 watts just idling. Not a huge deal but I'd still like to fix it.
Also my turbo_pct should be roughly 51 to be correct. Does not appear to be a way to change it that I can find. Perhaps the kernels are seeing my CPU as a non K version? Like 11900 instead of 11900k yet when I check things like hwinfo it shows 11900k
Powersave turbostat no quiet:
chris@pc-01:~$ sudo turbostat --Summary --show
Busy%,Bzy_MHz,IRQ,PkgWatt,PkgTmp,RAMWatt,GFXWatt,PKG_%
turbostat version 20.09.30 - Len Brown <lenb@kernel.org>
CPUID(0): GenuineIntel 0x1b CPUID levels; 0x80000008 xlevels;
family:model:stepping 0x6:a7:1 (6:167:1)
CPUID(1): SSE3 MONITOR SMX EIST TM2 TSC MSR ACPI-TM HT TM
CPUID(6): APERF, TURBO, DTS, PTM, HWP, HWPnotify, HWPwindow, HWPepp,
HWPpkg, EPB
cpu4: MSR_IA32_MISC_ENABLE: 0x00850089 (TCC EIST MWAIT PREFETCH TURBO)
CPUID(7): No-SGX
CPUID(0x15): eax_crystal: 2 ebx_tsc: 292 ecx_crystal_hz: 24000000
TSC: 3504 MHz (24000000 Hz * 292 / 2 / 1000000)
CPUID(0x16): base_mhz: 3500 max_mhz: 5300 bus_mhz: 100
cpu4: MSR_MISC_PWR_MGMT: 0x00401cc0 (ENable-EIST_Coordination DISable-
EPB DISable-OOB)
RAPL: 2097 sec. Joule Counter Range, at 125 Watts
cpu4: MSR_PLATFORM_INFO: 0x808083af1812300
8 * 100.0 = 800.0 MHz max efficiency frequency
35 * 100.0 = 3500.0 MHz base frequency
cpu4: MSR_IA32_POWER_CTL: 0x0034005d (C1E auto-promotion: DISabled)
cpu4: MSR_TURBO_RATIO_LIMIT: 0x3232323434353535
50 * 100.0 = 5000.0 MHz max turbo 8 active cores
50 * 100.0 = 5000.0 MHz max turbo 7 active cores
50 * 100.0 = 5000.0 MHz max turbo 6 active cores
52 * 100.0 = 5200.0 MHz max turbo 5 active cores
52 * 100.0 = 5200.0 MHz max turbo 4 active cores
53 * 100.0 = 5300.0 MHz max turbo 3 active cores
53 * 100.0 = 5300.0 MHz max turbo 2 active cores
53 * 100.0 = 5300.0 MHz max turbo 1 active cores
cpu4: MSR_CONFIG_TDP_NOMINAL: 0x00000023 (base_ratio=35)
cpu4: MSR_CONFIG_TDP_LEVEL_1: 0x001e02f8 (PKG_MIN_PWR_LVL1=0
PKG_MAX_PWR_LVL1=0 LVL1_RATIO=30 PKG_TDP_LVL1=760)
cpu4: MSR_CONFIG_TDP_LEVEL_2: 0x00000000 ()
cpu4: MSR_CONFIG_TDP_CONTROL: 0x00000000 ( lock=0)
cpu4: MSR_TURBO_ACTIVATION_RATIO: 0x00000000 (MAX_NON_TURBO_RATIO=0
lock=0)
cpu4: MSR_PKG_CST_CONFIG_CONTROL: 0x74000000 (UNdemote-C1, demote-C1,
UNlocked, pkg-cstate-limit=0 (pc0))
/dev/cpu_dma_latency: 2000000000 usec (default)
current_driver: intel_idle
current_governor: menu
current_governor_ro: menu
cpu4: POLL: CPUIDLE CORE POLL IDLE
cpu4: C1ACPI: ACPI FFH MWAIT 0x0
cpu4: C2ACPI: ACPI FFH MWAIT 0x31
cpu4: C3ACPI: ACPI FFH MWAIT 0x60
cpu4: cpufreq driver: intel_pstate
cpu4: cpufreq governor: powersave
cpufreq intel_pstate no_turbo: 0
cpu4: MSR_MISC_FEATURE_CONTROL: 0x00000000 (L2-Prefetch L2-Prefetch-
pair L1-Prefetch L1-IP-Prefetch)
cpu0: MSR_PM_ENABLE: 0x00000001 (HWP)
cpu0: MSR_HWP_CAPABILITIES: 0x010d2335 (high 53 guar 35 eff 13 low 1)
cpu0: MSR_HWP_REQUEST: 0x80003508 (min 8 max 53 des 0 epp 0x80 window
0x0
pkg 0x0)
cpu0: MSR_HWP_REQUEST_PKG: 0x8000ff01 (min 1 max 255 des 0 epp 0x80
window
0x0)
cpu0: MSR_HWP_INTERRUPT: 0x00000000 (Dis_Guaranteed_Perf_Change,
Dis_Excursion_Min)
cpu0: MSR_HWP_STATUS: 0x00000004 (No-Guaranteed_Perf_Change, No-
Excursion_Min)
cpu0: MSR_IA32_ENERGY_PERF_BIAS: 0x00000006 (balanced)
cpu0: MSR_RAPL_POWER_UNIT: 0x000a0e03 (0.125000 Watts, 0.000061
Joules,
0.000977 sec.)
cpu0: MSR_PKG_POWER_INFO: 0x000003e8 (125 W TDP, RAPL 0 - 0 W,
0.000000
sec.)
cpu0: MSR_PKG_POWER_LIMIT: 0x42fff800e5fff8 (UNlocked)
cpu0: PKG Limit #1: ENabled (4095.000000 Watts, 448.000000 sec, clamp
ENabled)
cpu0: PKG Limit #2: ENabled (4095.000000 Watts, 0.002441* sec, clamp
DISabled)
cpu0: MSR_DRAM_POWER_LIMIT: 0x5400de00000000 (UNlocked)
cpu0: DRAM Limit: DISabled (0.000000 Watts, 0.000977 sec, clamp
DISabled)
cpu0: MSR_PP0_POLICY: 0
cpu0: MSR_PP0_POWER_LIMIT: 0x00000000 (UNlocked)
cpu0: Cores Limit: DISabled (0.000000 Watts, 0.000977 sec, clamp
DISabled)
cpu0: MSR_PP1_POLICY: 0
cpu0: MSR_PP1_POWER_LIMIT: 0x00000000 (UNlocked)
cpu0: GFX Limit: DISabled (0.000000 Watts, 0.000977 sec, clamp
DISabled)
cpu4: MSR_IA32_TEMPERATURE_TARGET: 0x00640000 (100 C) (100 default - 0
offset)
cpu0: MSR_IA32_PACKAGE_THERM_STATUS: 0x88450000 (31 C)
cpu0: MSR_IA32_PACKAGE_THERM_INTERRUPT: 0x00000003 (100 C, 100 C)
cpu4: MSR_PKGC3_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu4: MSR_PKGC6_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu4: MSR_PKGC7_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu4: MSR_PKGC8_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu4: MSR_PKGC9_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu4: MSR_PKGC10_IRTL: 0x00000000 (NOTvalid, 0 ns)
0.76    1268    6511    30  16.87   0.00    0.00    0.00
0.89    983 9705    31  17.39   0.03    0.00    0.00
0.43    851 7473    31  17.03   0.00    0.00    0.00
0.36    800 5721    30  16.85   0.00    0.00    0.00
0.33    800 5427    30  16.80   0.00    0.00    0.00
0.34    800 5414    31  16.77   0.00    0.00    0.00
0.46    800 5744    30  16.61   0.01    0.00    0.00
0.48    800 2881    31  16.68   0.00    0.00    0.00
performance turbostat no quiet
HWPpkg, EPB
CPUID(7): No-SGX
EPB DISable-OOB)
lock=0)
cpu4: cpufreq governor: performance
cpu0: MSR_HWP_REQUEST: 0x00003535 (min 53 max 53 des 0 epp 0x0 window
0x0 pkg 0x0)
window 0x0)
Dis_Excursion_Min)
Excursion_Min)
Joules, 0.000977 sec.)
0.000000 sec.)
ENabled)
DISabled)
DISabled)
DISabled)
DISabled)
offset)
cpu0: MSR_IA32_PACKAGE_THERM_STATUS: 0x88410000 (35 C)
0.10    5295    2016    32  19.00   0.00    0.00    0.00
0.10    5297    2001    31  19.00   0.00    0.00    0.00
0.09    5298    1944    31  18.93   0.00    0.00    0.00
0.09    5297    1913    31  18.95   0.00    0.00    0.00
0.09    5298    1907    32  18.88   0.00    0.00    0.00
0.10    5287    1778    31  19.18   0.00    0.00    0.00
end
rsr911
  • 244
Note that running using the performance governor doesn't typically cause a lot of extra processor package heat dissipation. Yes, the CPUs run at higher frequencies, and the energy used is highly non-linear in the turbo region, but they also finish their work faster and therefore spend more time in deep idle states, consuming almost no energy. Examples, using a i5-10600K:
Powersave (HWP disabled):
doug@s19:~$ sudo turbostat --Summary --quiet --show Busy%,Bzy_MHz,IRQ,PkgWatt,PkgTmp,RAMWatt,GFXWatt,PKG_% --interval 15
0.08    1447    889     36      1.51    0.00    0.89    0.00
0.12    865     779     36      1.42    0.00    0.89    0.00
0.13    800     733     36      1.45    0.00    0.89    0.00
0.12    805     759     36      1.39    0.00    0.89    0.00
And Performance (HWP disabled):
0.03    4100    792     34      1.48    0.00    0.89    0.00
0.03    4100    658     34      1.52    0.00    0.89    0.00
0.03    4100    656     35      1.51    0.00    0.89    0.00
0.03    4100    749     35      1.62    0.00    0.89    0.00
Observe the cost was about 0.1 watts for an idle system.
And for not so idle (but still fairly idle), similar interrupts / sample period:
1.85    937     46458   33      1.90    0.00    0.89    0.00
2.02    815     46394   33      1.73    0.00    0.89    0.00
2.18    800     46647   33      1.74    0.00    0.89    0.00
2.23    800     46809   33      1.87    0.00    0.89    0.00
2.42    800     47187   33      1.79    0.00    0.89    0.00
2.60    800     48461   33      1.79    0.00    0.89    0.00
0.72    2404    46360   34      13.98   0.00    0.89    0.00
0.74    2478    46804   35      14.16   0.00    0.89    0.00
0.71    2752    47188   35      14.88   0.00    0.89    0.00
0.87    2458    47454   35      14.12   0.00    0.89    0.00
0.90    2511    48373   35      14.93   0.00    0.89    0.00
So, the cost is ~13 watts, a lot.
Powersave (HWP enabled):
1.13    1604    40861   37      10.55   0.00    0.89    0.00
1.13    1592    40709   37      10.56   0.00    0.89    0.00
1.14    1569    40826   37      10.56   0.00    0.89    0.00
1.15    1547    40959   37      10.50   0.00    0.89    0.00
1.16    1555    40936   37      10.32   0.00    0.89    0.00
1.00    1733    41003   37      11.39   0.00    0.89    0.00
Performance (HWP enabled):
0.57    3484    43276   37      15.18   0.00    0.89    0.00
0.62    2749    44102   37      14.99   0.00    0.89    0.00
0.65    2493    44177   38      15.24   0.00    0.89    0.00
0.65    2476    44166   37      15.07   0.00    0.89    0.00
0.65    2474    44163   37      15.14   0.00    0.89    0.00
About 4.5 watts.
EDITED: Now, your intel_pstate parameters are interesting, but my understanding of the definition of the numbers was incorrect:
From the documentation:
Sysfs will show :
    max_perf_pct:100, which corresponds to 1 core ratio
    min_perf_pct:24, max_efficiency_ratio / max 1 Core ratio
    no_turbo:0, turbo is not disabled
    num_pstates:26 = (max 1 Core ratio - Max Efficiency Ratio + 1)
    turbo_pct:39 = (max 1 core ratio - max non turbo ratio) / num_pstates
From the code:
static ssize_t show_turbo_pct(struct kobject *kobj,
                                struct kobj_attribute *attr, char *buf)
        struct cpudata *cpu;
        int total, no_turbo, turbo_pct;
        uint32_t turbo_fp;
    mutex_lock(&amp;intel_pstate_driver_lock);
    if (!intel_pstate_driver) {
            mutex_unlock(&amp;intel_pstate_driver_lock);
            return -EAGAIN;
    cpu = all_cpu_data[0];
    total = cpu-&gt;pstate.turbo_pstate - cpu-&gt;pstate.min_pstate + 1;
    no_turbo = cpu-&gt;pstate.max_pstate - cpu-&gt;pstate.min_pstate + 1;
    turbo_fp = div_fp(no_turbo, total);
    turbo_pct = 100 - fp_toint(mul_fp(turbo_fp, int_tofp(100)));
    return sprintf(buf, &quot;%u\n&quot;, turbo_pct);
So, for your processor, the specs are 3.5 GHz base frequency, 0.8 GHz min, 5.3 GHz max.
(53 - 35) / 46 = 39% for your case. Close enough, and doing it the exact code way, gives 40%.
EDIT 2: Please see this article. Most relevant extract:
What this means is that, if all 8 cores are loaded, TB2 means that it will run at 4.7 GHz. If there is power budget and thermal budget, it will attempt 4.8 GHz. If there is more power budget and thermal budget available, it will go to 4.9 GHz, then 5.0 GHz, then 5.1 GHz. The frequency will float as long as it has enough of those budgets to play with, and it will increase/decrease as necessary. This is important as different instructions cause different amounts of power draw and such.
Doug Smythies
  • 16,146
Turns out this was a bios issue with the CPU frequency. I was running an updated version (0704), updated to 0707 that was released 4/28/2021 and now my CPU will run at full speed under load.
Here's a link to the latest bios from Asus: https://rog.asus.com/us/motherboards/rog-strix/rog-strix-z590-e-gaming-wifi-model/helpdesk_bios
Now I will check my networking and see if anything changed there. Still will not boot into the GUI on mainline kernels or stock kernels without an add in graphics card.
Networking checked with iperf. Still running at 1gb instead of 2.5
rsr911
  • 244
