I have troubles installing libsqlite3-0-dbgsym due to unmet dependencies, but the right dependency seems to be installed. Anyone have a suggestion?
mathieu@linda:~ $ sudo apt install libsqlite3-0-dbgsym
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: libsqlite3-0-dbgsym : Depends: libsqlite3-0 (= 3.31.1-4) but 3.31.1-4ubuntu0.2 is to be installed E: Unable to correct problems, you have held broken packages.
mathieu@linda:~ $ sudo apt list --installed | grep sqlite
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libsqlite3-0/focal-updates,focal-security,now 3.31.1-4ubuntu0.2 amd64 [installed]
libsqlite3-dev/focal-updates,focal-security,now 3.31.1-4ubuntu0.2 amd64 [installed]
