On a Ubuntu Server LTS 20.x, with renderer : networkd, LAN / WAN Connectivity are all properly fucntional. However in Cockpit > Software Updates, it gives the error message:
Loading available updates failed
Cannot refresh cache whilst offline
Changing the setting to renderer : NetworkManager
makes Cockpit > Software Updates work flawlessly without impacting the Networking module in Cockpit.
But I would rather stick to renderer : networkd as this is a Server.
Any insight to get renderer : networkd to work ? Or Cockpit just 'needs' NetworkManager ?
Note:
sudo systemctl stop network-manager.service
sudo systemctl disable network-manager.service
Will make the Networking module in cockpit fail with error :
Network devices and graphs require NetworkManager
MarcoZen
  • 281
Apparently Cockpit just 'needs' Network Manager.
That was hinted at in my question as well.
Changing the setting to renderer : NetworkManager makes Cockpit > Software Updates work flawlessly without impacting the Networking module in Cockpit.
Other workarounds cause some modules ( especially the Networking module ) to not function properly. Cockpit project github reference -> https://github.com/cockpit-project/cockpit/issues/15746
Note : This method also ensures that when you use Cockpit to manage your Virtual Machines, creating bridges etc work flawlessly as well.
MarcoZen
  • 281
According to this, the easiest workaround until Ubuntu settles on a network manager is this:
nmcli con add type dummy con-name fake ifname fake0 ip4 1.2.3.4/24 gw4 1.2.3.1
The issue is still valid on Ubuntu 22.04 LTS.
The FAQ on Cockpit's web pages provides steps for a workaround (and explanation as well):
  1. Create a placeholder file and network interface. Create /etc/NetworkManager/conf.d/10-globally-managed-devices.conf with the contents:
[keyfile]
unmanaged-devices=none
  1. If you run on Ubuntu with arm64 (e.g.: on a Raspberry Pi), install extra Linux kernel modules for networking:
sudo apt install linux-modules-extra-raspi
  1. Set up a “dummy” network interface:
  1. Reboot
