I'm having difficulty starting samba on ubuntu
How can I see what ports are open on my machine?
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# sudo netstat -ntlp | grep LISTEN
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      34237/systemd-resol
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      34174/sshd: /usr/sb
tcp6       0      0 :::22                   :::*                    LISTEN      34174/sshd: /usr/sb
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~#
https://ubuntu.com/tutorials/install-and-configure-samba
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# sudo apt install samba
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# mkdir samba
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# ls -l total 12 drwxr-xr-x 2 root root 4096 Apr 23 18:01 abc drwxr-xr-x 2 root root 4096 Apr 24 01:27 samba drwxr-xr-x 3 root root 4096 Apr 23 17:26 snap
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# cd samba/ root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~/samba# ls root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~/samba# cd ..
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# cd /root/samba root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~/samba# ls root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~/samba# cd ..
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# sudo nano /etc/samba/smb.conf
(added lines suggested in that guide but adjusted the path line to the directory I created) i.e.
[sambashare] comment = Samba on Ubuntu path = /root/samba read only = no browsable = yes
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# sudo service smbd restart root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# sudo ufw allow samba Rules updated Rules updated (v6)
( could use any username but used root)
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# sudo smbpasswd -a root New SMB password: Retype new SMB password: Added user root.
root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~# netstat -ntlp Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 51395/smbd tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 51395/smbd tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 34237/systemd-resol tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 34174/sshd: /usr/sb tcp6 0 0 :::445 :::* LISTEN 51395/smbd tcp6 0 0 :::139 :::* LISTEN 51395/smbd tcp6 0 0 :::22 :::* LISTEN 34174/sshd: /usr/sb root@ubuntu-s-1vcpu-1gb-intel-nyc1-01:~#
I can SSH to that ubuntu server.. and I see 0.0.0.0:22 there.
When I go from another computer and do
$nmap -p22,445 157.111.214.123
Starting Nmap 7.91 ( https://nmap.org ) at 2021-04-24 02:44 GMT Daylight Time
Nmap scan report for 157.111.214.123
Host is up (0.084s latency).
PORT STATE SERVICE 22/tcp open ssh 445/tcp filtered microsoft-ds
Nmap done: 1 IP address (1 host up) scanned in 2.43 seconds
(From what I understand "filtered" is as good as closed.. so rather than the port reply as closed it doesn't reply at all.. so some device e.g. a firewall is not responding to indicate that the port is open).
When I try to access the SAMBA share from (dare I say a windows machine), e.g. \\IP or net use \\IP, it doesn't work. But not surprising, 'cos nmap shows PORT 445 as not open.
barlop
  • 125
