I'm trying to apt upgrade my system, but it fails with:
You might want to run 'apt --fix-broken install' to correct these.
ubuntu-server : Depends: motd-news-config but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
So I try apt --fix-broken install which shows:
The following additional packages will be installed:
base-files motd-news-config
The following NEW packages will be installed:
motd-news-config
The following packages will be upgraded:
base-files
But it fails with:
Preparing to unpack .../base-files_10.1ubuntu2.10_amd64.deb ...
Warning: Stopping motd-news.service, but it can still be activated by:
motd-news.timer
Unpacking base-files (10.1ubuntu2.10) over (10.1ubuntu2.9) ...
dpkg: error processing archive /var/cache/apt/archives/base-files_10.1ubuntu2.10_amd64.deb (--unpack):
unable to create '/usr/bin/locale-check.dpkg-new' (while processing './usr/bin/locale-check'): Operation not permitted
Reinstalling /etc/default/motd-news that was backed-up
motd-news.service is a disabled or a static unit, not starting it.
So finally I try apt install motd-news-config but it fails with:
motd-news-config : Breaks: base-files (< 10.1ubuntu2.10) but 10.1ubuntu2.9 is to be installed
I don't understand what's going on here. It seems that the upgrade requires a version of base-files incompatible with motd-news-config, which is also required for the update. I've also tried searching around for unable to create '/usr/bin/locale-check.dpkg-new' which could be the actual source of the errors, but I could not find any information on it. Any help, please?
Update:
List of PPAs from grep ^ /etc/apt/sources.list /etc/apt/sources.list.d/*:
deb http://mirrors.digitalocean.com/ubuntu/ bionic main restricted
deb http://mirrors.digitalocean.com/ubuntu/ bionic-updates main restricted
deb http://mirrors.digitalocean.com/ubuntu/ bionic universe
deb http://mirrors.digitalocean.com/ubuntu/ bionic-updates universe
deb http://mirrors.digitalocean.com/ubuntu/ bionic multiverse
deb http://mirrors.digitalocean.com/ubuntu/ bionic-updates multiverse
deb http://mirrors.digitalocean.com/ubuntu/ bionic-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu bionic-security main restricted
deb http://security.ubuntu.com/ubuntu bionic-security universe
deb http://security.ubuntu.com/ubuntu bionic-security multiverse
