After the last update on Ubuntu 18.04 (4.15.0-142-generic) my wifi fails to find any networks. wifi not finding images
When I run sudo lshw -C network I get the following:
 *-generic DISABLED
   description: Wireless interface
   product: Illegal Vendor ID
   vendor: Illegal Vendor ID
   physical id: 0
   bus info: pci@0000:07:00.0
   logical name: wlp7s0
   version: ff
   serial: 28:3a:4d:7d:30:15
   width: 32 bits
   clock: 66MHz
   capabilities: bus_master vga_palette cap_list ethernet physical wireless
   configuration: broadcast=yes driver=r8822be driverversion=4.15.0-142-generic firmware=N/A latency=255 link=no maxlatency=255 mingnt=255 multicast=yes wireless=IEEE 802.11
   resources: irq:144 ioport:4000(size=256) memory:a4300000-a430ffff
*-network description: Ethernet interface product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:08:00.0 logical name: enp8s0 version: 15 serial: e8:6a:64:7e:19:c4 size: 10Mbit/s capacity: 1Gbit/s width: 64 bits clock: 33MHz capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII speed=10Mbit/s resources: irq:17 ioport:3000(size=256) memory:a4204000-a4204fff memory:a4200000-a4203fff
*-network description: Ethernet interface physical id: 3 logical name: enp0s20f0u2 serial: 02:61:1f:5b:f1:72 capabilities: ethernet physical configuration: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.200.64 link=yes multicast=yes
and ifconfig:
enp0s20f0u2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    inet 192.168.200.64  netmask 255.255.255.0  broadcast 192.168.200.255
    inet6 fe80::6045:696e:c17d:8342  prefixlen 64  scopeid 0x20<link>
    ether 02:61:1f:5b:f1:72  txqueuelen 1000  (Ethernet)
    RX packets 13878  bytes 12536453 (12.5 MB)
    RX errors 8  dropped 0  overruns 0  frame 8
    TX packets 8995  bytes 2533335 (2.5 MB)
    TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enp8s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether e8:6a:64:7e:19:c4 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 622 bytes 55833 (55.8 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 622 bytes 55833 (55.8 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
If i try to sudo ifconfig wlp7s0 up I get SIOCSIFFLAGS: Operation not permitted
dmesg:
[   43.536416] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   43.536417] Bluetooth: BNEP filters: protocol multicast
[   43.536418] Bluetooth: BNEP socket layer initialized
[   46.696451] IPv6: ADDRCONF(NETDEV_UP): enp0s20f0u2: link is not ready
[   46.703136] IPv6: ADDRCONF(NETDEV_UP): enp8s0: link is not ready
[   46.774164] r8169 0000:08:00.0 enp8s0: link down
[   46.774317] IPv6: ADDRCONF(NETDEV_UP): enp8s0: link is not ready
[   46.802975] IPv6: ADDRCONF(NETDEV_UP): wlp7s0: link is not ready
[   46.827476] r8822be: halmac_init_hal failed
[   46.951349] r8822be: halmac_init_hal failed
[   46.952202] r8822be: halmac_init_hal failed
[   49.495101] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found
[Buffer], ACPI requires [Package] (20170831/nsarguments-100)
[   57.008614] r8822be: halmac_init_hal failed
[   57.009144] r8822be: halmac_init_hal failed
[   67.013206] r8822be: halmac_init_hal failed
[   67.013534] r8822be: halmac_init_hal failed
[   77.057025] r8822be: halmac_init_hal failed
[   77.057611] r8822be: halmac_init_hal failed
[   80.383128] Bluetooth: RFCOMM TTY layer initialized
[   80.383131] Bluetooth: RFCOMM socket layer initialized
[   80.383133] Bluetooth: RFCOMM ver 1.11
[   83.289169] rfkill: input handler disabled
[   83.411293] acpi INT3400:00: Unsupported event [0x88]
[   84.429167] acpi INT3400:00: Unsupported event [0x88]
[   87.084368] r8822be: halmac_init_hal failed
[   87.085163] r8822be: halmac_init_hal failed
[   97.097929] r8822be: halmac_init_hal failed
[   97.098484] r8822be: halmac_init_hal failed
[  218.697420] acpi INT3400:00: Unsupported event [0x86]
[  352.725607] usb 1-3: USB disconnect, device number 3
[  446.861695] CPU8: Core temperature above threshold, cpu clock throttled (total events = 3)
[  446.861696] CPU4: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861697] CPU0: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861697] CPU2: Core temperature above threshold, cpu clock throttled (total events = 3)
[  446.861698] CPU1: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861699] CPU7: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861700] CPU6: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861701] CPU10: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861701] CPU2: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861702] CPU8: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861737] CPU3: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861737] CPU9: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861738] CPU11: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.861739] CPU5: Package temperature above threshold, cpu clock throttled (total events = 4)
[  446.862763] CPU8: Core temperature/speed normal
[  446.862764] CPU8: Package temperature/speed normal
[  446.862765] CPU0: Package temperature/speed normal
[  446.862765] CPU2: Core temperature/speed normal
[  446.862766] CPU4: Package temperature/speed normal
[  446.862767] CPU10: Package temperature/speed normal
[  446.862767] CPU6: Package temperature/speed normal
[  446.862767] CPU2: Package temperature/speed normal
[  446.862825] CPU1: Package temperature/speed normal
[  446.862826] CPU7: Package temperature/speed normal
[  446.862826] CPU9: Package temperature/speed normal
[  446.862827] CPU3: Package temperature/speed normal
[  446.862828] CPU11: Package temperature/speed normal
[  446.862828] CPU5: Package temperature/speed normal
[ 2826.974988] r8822be: halmac_init_hal failed
[ 2848.005392] r8822be: halmac_init_hal failed
I can't find a way to fix it by myself, would gladly accept any help Thank you
EDIT:
rfkill list all :
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
3: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
I actually just solved it by just loading windows and then loading ubuntu again (I have dual boot) as someone mentioned... Very weird but its working... also added rfkill list all for sport, and dmesg shows everything is ok with r8822be driver now
